help! xubuntu 7.10 + wine 0.9.46
paulo_gomes
indigo wont run on it, it gives me this error:
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls"
err:module:LdrInitializeThunk "MSVCR80.dll" failed to initialize, aborting
err:module:LdrInitializeThunk Main exe initialization for L"Z:\\home\\paulo\\soft\\indigo\\indigo.exe" failed, status c0000142
anyone?
thanks
anyone?
thanks
- joegiampaoli
just for kicks try wine 0.9.47
Here's a small tut forindigo on linux I wrote, hope it helps:
http://www.indigorenderer.com/joomla/fo ... php?t=2921
I think you will be able to get it working by simply inserting a new xml file in the folder!
it has to be called:
and the content is:
it always worked for me on ubuntu!
Microsoft.Windows.Common-Controls.manifestCode: Select all
<?xml version="1.0" encoding="UTF-8" ?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
<assemblyIdentity type="win32" name="Microsoft.Windows.Common-Controls"
version="6.0.0.0" processorArchitecture="x86" />
<file name="comctl32.dll" />
</assembly>-
paulo_gomes
hi all, thanks for your replys,
i'm using indigo 1, but version 0.9 gives me the same error, this occured because i've upgraded from xubuntu 7.04 to 7.10, before that it was all working fine
psor, i already have a file called Microsoft.VC80.CRT.manifest in the root of indigo
WyRaven, i've try the linux version, but my cpu doesn't work with ss2.
Joegiampaoli, thats a very good doc, you should put it in the wiki, but it doesn't mention my problem. i think i'll have to upgrade wine.
dandy, i've created the file an put it in the root of indigo, but it doesn't work also.
thank you all.
thank you all.
I am so sure that my solution should work for you since every time I upgrade my indigo version I get the same error as you that I uploaded my file just in case something went wrong while creating it on yours...
http://rapidshare.com/files/67707499/Mi ... ifest.html
hope this helps man!
paulo_gomes
- joegiampaoli
Hmmm, I'm gonna have to take a look at this error, I never got it on my ubuntu box, since I am using latest indigo (1.01) I am not sure if also installing Microsoft Visual C++ under wine helps, I will have to do some testing with older versions to update the manual I did. But take in mind the manual is aimed at newer indigo versions, I would advice you to use the latest, and you could help me confirm maybe if you still get that error with the latest indigo version.
- joegiampaoli
Ok, I did a quick test, moved my .wine so new one would be recreated and tested with indigo 9 and latest and never got this error, could be a 64 bit isuue maybe?
@dandy:
Do you also use xubuntu (although I doubt that has anything to do).
@paulo_gomes:
Do you also use 64 bit ubuntu? (This will help me confirm that's probably the main isuue)
Then I can update the tutorial with some section like "In case you get this error....."
Thx
@dandy:
@paulo_gomes:
Thx
paulo_gomes
- joegiampaoli
Ok did you alredy install latest wine from the official website, if no, you can add it to your repos and do an "apt-get update" then "apt-get upgrade".
Here's the link to the wine repos:
http://www.winehq.org/site/download-deb
Tell me what happens.
Thx.
EDIT:
If you already had done this before doing your ubuntu upgrade you still have to change the repos for wine, because they will not update by themselves.
Thx.
EDIT:
