Guide For Exporter Writers
Post by OnoSendai » Wed Oct 24, 2007 9:35 pm
Added a ' General procedure for setting the camera settings' section.
Post by fused » Wed Oct 24, 2007 9:38 pm
nice. thank you!
finally a "camera for dummies" :)
Post by Whaat » Mon Oct 29, 2007 3:14 pm
Hey Indigo people!
What's a good default pre-scale value? SkIndigo has been using 6.0 for a long time and I am starting to notice that most the of renders uploaded by new SkIndigo users look like the pre-scale is set too high.
I think the reason I set it so high is because my old computer had a really dark monitor and I had to use a higher pre-scale value for the render to look right. Now, when I see renders on my new laptop and my computer at work, they look too bright.
Maybe a value of 4.0 (like Blendigo) is the way to go. It should be a value that will give a good render for a variety of lighting situations.
Does anyone find Blendigo's default value of 4.0 too low? Too high?
Thanx.
Post by Zom-B » Mon Oct 29, 2007 9:16 pm
Whaat wrote:What's a good default pre-scale value?
3/1/10 for reinhard is cool on all my three CRT's (but violets reinhard settings are way brighter using this values :?: ).
Post by Kram1032 » Tue Oct 30, 2007 12:10 am
Violet's values are logarithmic, I think...
Someone, I can't remember, who, programmed it like that, so that a post scale value change of 1 will cause the histogram to be one stop brighter or darker ;)
CoolColJ
Post by CoolColJ » Tue Oct 30, 2007 9:44 am
In Voilet 0=1 in Indigo
I tend to use a burn of 5, 4 will kinda burn out, but it changes from render to render. I hate Reinhart anyway, looks too "grey" :)
Ana028
Post by Ana028 » Fri Nov 02, 2007 12:32 am
Hi all, I have a question about how can I calc the aperture radius
I have a camera with 24mm focal lenght, zoom factor 3.2, focal dis 1 and camera f-stop 4.
We have
N = f / d
where
N = f-number, f = focal length, d = aperture diameter.
Therefore
r = f / (N*2)
where
r = aperture radius.
I don't understand very good this. How can I calc the aperture radius with my values ?
Post by suvakas » Fri Nov 02, 2007 12:58 am
Here is how I do it for Maxigo:
f-stop = 4
sensor_width = 0.035
sensor_distance = sensor_width / (2*tan(cameraFOV/2))
aperture_radius = sensor_distance / ( f-stop * 2)
Ana028
Post by Ana028 » Fri Nov 02, 2007 1:06 am
Thanks, :wink:
bkircher
Post by bkircher » Fri Nov 02, 2007 7:01 pm
While trying to write Rotation Matrixes for the MayaToIndigo exporter,
well, we got stuck. I checked the Skindigo tool but couldn't find any reference to rotation code.
As this will eventually concern every exporter that generates instances or that will implement efficient transformation-based animations, can somebody shed some light on this?
Here is the baby-code for generating rotation matrixes, or at least some starting point. I imagine it will be something similar for other programming / script languages.
$x = `getAttr locator1.rx`;
$y = `getAttr locator1.ry`;
$z = `getAttr locator1.rz`;
float $xCos = cos (deg_to_rad($x));
float $xCo_ = -1 * `cos (deg_to_rad($x))`;
float $xSin = `sin (deg_to_rad($x))`;
float $xSi_ = -1 * `sin (deg_to_rad($x))`;
float $yCos = `cos (deg_to_rad($y))`;
float $yCo_ = -1 * `cos (deg_to_rad($y))`;
float $ySin = `sin (deg_to_rad($y))`;
float $ySi_ = -1 * `sin (deg_to_rad($y))`;
float $zCos = `cos (deg_to_rad($y))`;
float $zCo_ = -1 * `cos (deg_to_rad($y))`;
float $zSin = `sin (deg_to_rad($y))`;
float $zSi_ = -1 * `sin (deg_to_rad($y))`;
matrix $mx[3][3] = << 1 , 0 , 0 ;
            0 , $xCos, $xSi_;
            0 , $xSin, $xCos>>;
matrix $my[3][3] = << $yCos , 0 , $ySin ;
            0 , 1, 0 ;
            $yCo_ , 0, $yCos>>;
matrix $mz[3][3] = << $zCos , $zSi_ , 0 ;
            $zSin , $zCos, 0;
            0 , 0, 1>>;
matrix $mAll[3][3] = $mx * $my * $mz;
print "\nrotation Matrix:";
print $mAll;
Post by CTZn » Sat Nov 03, 2007 2:05 am
And as a reference, the latest version wich works only for rotations around up axis.
				float $xCos = cos (deg_to_rad($rix));
				float $xCo_ = -1 * `cos (deg_to_rad($rix))`;
				float $xSin = `sin (deg_to_rad($rix))`;
				float $xSi_ = -1 * `sin (deg_to_rad($rix))`;
				float $yCos = `cos (deg_to_rad($riy))`;
				float $yCo_ = -1 * `cos (deg_to_rad($riy))`;
				float $ySin = `sin (deg_to_rad($riy))`;
				float $ySi_ = -1 * `sin (deg_to_rad($riy))`;
				float $zCos = `cos (deg_to_rad($riz))`;
				float $zCo_ = -1 * `cos (deg_to_rad($riz))`;
				float $zSin = `sin (deg_to_rad($riz))`;
				float $zSi_ = -1 * `sin (deg_to_rad($riz))`;
				matrix $R0[3][3] = << $zCos , $zSi_ , 0 ;
				            $zSin , $zCos, 0;
				            0 , 0, 1>>;
				matrix $Rx[3][3] = << 1 , 0 , 0 ;
				            0 , $xCos, $xSi_;
				            0 , $xSin, $xCos>>;
				matrix $R1[3][3] = << $yCos , $ySi_ , 0 ;
				            $ySin , $yCos, 0;
				            0 , 0, 1>>;
				matrix $Rresult[3][3] = $R1 * $Rx;
				matrix $Rresult[3][3] = $Rresult * $R0;
				print $Rresult;
				matrix $RtoY [3][3] = <<1, 0, 0;
										0, 0, -1;
										0, 1, 0>>;
				if ($upAxis == "y")
					$Rresult = $Rresult * $RtoY;
This approach is as follows (Z up):
1° Rotation around Z
2° Rotation aroun X
3° Second rotation around Z
Here I can't define the value for the second rotation around Z, I'm using Y rot value but seems wrong.
Indeed we need help. Thanks.
Post by suvakas » Sat Nov 03, 2007 2:48 am
Why are you doing this manually?
Can't you get a nice rotation/transform matrix out of Maya?
Post by Whaat » Sat Nov 03, 2007 2:55 am
suvakas wrote:Why are you doing this manually?
Yeah, it's EZ with SketchUp API.
trans=entity.transformation
Done!
Post by CTZn » Sat Nov 03, 2007 7:02 am
I can't answer your question suvakas, as the code I expose here is from someone's else algorithm and it appeared that afternoon that he hadn't the problem clear in mind so the algorithm is finally not suitable.
I do ignore almost everything about rotation matrices...
Anyhow the "how" is not the point here, we need to know the right composition of the RM and their multiplication order, if I understood enough. Thought you guys had cracked that easily...
That said, suvakas, that was a good question. Inquiring now...
>> Indeed every object has:
- matrix
- world matrix
- parent matrix
and each of these has an inverse matrix also available as output. bkircher, maybe we have been fooled...
bkircher
Post by bkircher » Sat Nov 03, 2007 11:45 am
Sadly, we can't.
But the Maya Help is great in that respect:
              -1                      -1
   matrix = SP * S * SH * SP * ST * RP * RA * R * RP * RT * T
a little further down the line, it is said:
RX = |  1    0    0    0 |     RY = |  cy   0   -sy   0 |
                                 |  0    cx   sx   0 |          |  0    1    0    0 |
                                 |  0   -sx   cx   0 |          |  sy   0    cy   0 |
                                 |  0    0    0    1 |          |  0    0    0    1 |
                        RZ = |  cz   sz   0    0 |     sx = sin(rx), cx = cos(rx)
                                 | -sz   cz   0    0 |     sy = sin(ry), cx = cos(ry)
                                 |  0    0    1    0 |     sz = sin(rz), cz = cos(rz)
                                 |  0    0    0    1 |
, and well, that's it, basically.
Maya is thinking Y-up to my experience: In a Z-up environment, probably a XYZ rotation order with Y up is part of the problem?
(We can get the world 4x4 matrix, does this help ?)
Any help is appreciated on this issue...
