How use blend material?
7 posts • Page 1 of 1
Xman
Post by Xman » Fri Nov 02, 2007 3:53 am
Hello Max user,
How use a blend material? Can you provide some instruction?
Thanks your :D
***Xman***
Post by suvakas » Fri Nov 02, 2007 5:32 am
Hmm..are you serious ?
Search for "Blend Material" from 3ds Max help file. Indigo material works quite the same way.
Xman
Post by Xman » Fri Nov 02, 2007 6:01 am
Yes Suvakas,Because I am a C4D user.But I like your Maxigo very much.
thanks you,I work hard to try :) I hope know how to use blend or can see some examples only. :D
Post by suvakas » Fri Nov 02, 2007 6:38 am
Oh, you're a C4D user? You got me then :lol:
I've always thought that you're a max user.
Well..blend material combines 2 different materials using either mask ( a texture map) or constant mix amount.
I did a quick example:
Xman
Post by Xman » Fri Nov 02, 2007 7:26 am
suvakas,thank you Thus clear instruction.
Post by suvakas » Fri Nov 02, 2007 7:35 am
You're welcome.
Just to remind you, that you can also blend another blend materials. For example you can use this blue/yellow-checker blend as Material 1 and something else for Material 2 and then you can blend between those and so on.
Xman
Post by Xman » Fri Nov 02, 2007 5:41 pm
Thanks for you so great help to me,I will test different material.
:D
