Yup or Zup ?
In your main 3d application, the up axis is set to:
Y
16
35%
Z
30
65%
Total votes: 46
Silverman
Post by Silverman » Thu Nov 01, 2007 7:47 am
Kram1032 wrote:
Silverman wrote:The Z up assumes you are on a planet.
Yeah, the starting point is the Cartesian plane, with x across and y up. If you maintain the orientation of looking at that plane then the only place to add the third dimension is to have it coming off the plane, which would be toward/away from the viewer (Yup). The Zup orientation also starts with the x-y Cartesian plane but rotates the plane as if being viewed at an angle, allowing Z to be up. My thinking is that the Zup orientation places the Cartesian plane on the ground, which implies a planet or some other orienting object. Yup does not, the only orienting object is the viewer, to my thinking that is more basic and universal. :shock:
Post by Kram1032 » Thu Nov 01, 2007 8:36 am
It really depends on your PoV...
To me, Zup is more logic...
Perhaps, 'cause I looked down on the tiny details on the ground, in my very young ages? :)
crc
Post by crc » Thu Nov 01, 2007 10:34 am
X,Y,Z ???? I have Red, Green, Blue :shock:
Post by Kram1032 » Thu Nov 01, 2007 10:36 am
X RED
(in Zup:)
Y GREEN
Z BLUE
no idea, what's with Yup....
dougal2
Post by dougal2 » Thu Nov 01, 2007 10:40 am
colours are the same in Maya (Yup) Kram
Post by CTZn » Thu Nov 01, 2007 2:34 pm
By the way you can set Maya to Z up...
Post by lycium » Thu Nov 01, 2007 8:37 pm
CTZn wrote:
Kram wrote:For me, personally, Zup is the more logic way. You look down on a sheet of paper, so that x is left and right, where as y is farther away and closer to you. So, the next dimension to add is upward by using Zup.
Well if that's logic, what about the blackboard you learned maths on ? Was it on your knees :P ?
heh, this is also how i feel (you just take your normal highschool axes, and add a z axis perpendicular to them), and why all 3d software i write uses y-up :)
Users browsing this forum: No registered users and 103 guests
