Max Num Consec Rejections (MNCR) doesn't speed up or slow down your render.
It simply reduces Fireflies but also caustics
in this release, 1000 is quite ok
But the genius, in this forum, with these values, is CoolColJ
don't use a LM that low, try 0.4 to 0.5!slamdog wrote: some technical questions...
i'm using these settings:
LM prob=0.1
Max Change=0.03
Max num cons rej=2000
Max Depth=600
SuperSample=3
low values of Maxnumconsrej speeds up convergence? and can affect the "realism" of the scene?
Other question: there's a way to reduce the render time per sample?
bye bye
Be aware of the untonemapped.exrslamdog wrote:in the blendigo exporter i've checked the option that saves the untonemapped exr, then i will edit with qtpfsgui.
bye bye
