MtI rev 32 29 oct 2007
Post by CTZn » Tue Oct 30, 2007 5:40 am
could you please add you changes to the log message when you commit though? cheers.
Will do for sure, missed it !
As for limits: kick them off !!! We don't want to prevent users to test Indigo. How would you make *very hot* metal ? I'ts a light emitter already at 1200°K I bet.
dougal2
Post by dougal2 » Tue Oct 30, 2007 5:44 am
Post by CTZn » Tue Oct 30, 2007 5:48 am
fine then. Put it a 500 :D
bkircher
Post by bkircher » Tue Oct 30, 2007 7:17 am
500 is fine with me!
We should probably also add a statement that hints at low values of power drawn / efficacy if the values are within the range of 0..1. (Do we need a feedback line?)
Concerning the Rotation Matrix:
I've made a small proof of concept, even though the result has a different orientation than I wanted it to be...
$x = `getAttr locator1.rx`;
$y = `getAttr locator1.ry`;
$z = `getAttr locator1.rz`;
float $xCos = cos (deg_to_rad($x));
float $xCo_ = -1 * `cos (deg_to_rad($x))`;
float $xSin = `sin (deg_to_rad($x))`;
float $xSi_ = -1 * `sin (deg_to_rad($x))`;
float $yCos = `cos (deg_to_rad($y))`;
float $yCo_ = -1 * `cos (deg_to_rad($y))`;
float $ySin = `sin (deg_to_rad($y))`;
float $ySi_ = -1 * `sin (deg_to_rad($y))`;
float $zCos = `cos (deg_to_rad($y))`;
float $zCo_ = -1 * `cos (deg_to_rad($y))`;
float $zSin = `sin (deg_to_rad($y))`;
float $zSi_ = -1 * `sin (deg_to_rad($y))`;
matrix $mx[3][3] = << 1 , 0 , 0 ;
		      0 , $xCos, $xSi_;
		      0 , $xSin, $xCos>>;
matrix $my[3][3] = << $yCos , 0 , $ySin ;
		      0 , 1, 0 ;
		      $yCo_ , 0, $yCos>>;
matrix $mz[3][3] = << $zCos , $zSi_ , 0 ;
		      $zSin , $zCos, 0;
		      0 , 0, 1>>;
matrix $mAll[3][3] = $mx * $my * $mz;
print "\nrotation Matrix:";
print $mAll;
print "\n";
http://en.wikipedia.org/wiki/Rotation_r ... ematics%29
That is still a first shot, and I think the conventions may differ, but the syntax works.
cheers,
b
Post by CTZn » Tue Oct 30, 2007 11:26 am
According to my reference $mx, $mz look correct, for $my try:
matrix $my[3][3] = << $yCos , $ySi_ , 0 ;
            $ySin  , $yCos , 0 ;
            0 , 0, 1>>;
Should work for z up. Also I'm told that the final result has to be multiplied by
       <<1 0 0
         0 0 -1
         0 1 0>>
to work for Y up if I understand correctly.
Post by CTZn » Tue Oct 30, 2007 12:45 pm
REV 36
- fixed initialShadingGroup bug
Ooops just realised instances are wrong with Y up :mrgreen:
I'll do the rotation matrices after, or will you bkircher ? What is your status on that ?
Post by CTZn » Tue Oct 30, 2007 1:33 pm
REV 37
- Fixed instances with Y up
- Added scale for instances
- updated documentation
Ready to have an insight of rotatrice mations right now ! bkircher I'm using your code as a basis, thx for the writing !
dougal2
Post by dougal2 » Wed Oct 31, 2007 12:22 am
can we put in the mtiSettings.txt back in for saving the indigo path?
I don't mind having to set up all the render settings for each new scene, but to keep inputting the path, which is always the same is a little tedious and boring. Also, changing the path in the file will then update every scene when the user installs a new indigo version :)
(another thought - I presume mti_settings.mti_version exists so that if major changes are made to the ScriptNode, we can detect this and update the scene with new ScriptNode attributes??)
edit: REV 38 - added, but left commented out, the code to read indigo path from file in mti_ScriptNode.mel
dougal2
Post by dougal2 » Wed Oct 31, 2007 1:10 am
ok, so what's happening here?
Post by Kram1032 » Wed Oct 31, 2007 1:13 am
I tried it out, yesterday: lowest blackbody value that still gave emission was at 227.9 K - 227.8 rendered black ;) I didn't try more accurate decimals, though...
Post by CTZn » Wed Oct 31, 2007 2:47 am
Thanks for the test, Kram.
There is a bug I think where instances are flipped in the Z (depth) axis. I think I know where it is but for the following hours I'll be on an urgent work.
$upAxis = `eval "getAttr mti_settings.mti_cameraUpAxis"`;
now returns 0 or 1 and not "Y" or "Z" :roll:
Gotta check that tonight. I've just fixed sun but won't commit before I fix that all.
Yep many scriptNode attr should be written on a file read when calling mti IMO, more explicit names for paths (eg Indigo(Install||App||Bin)Dir & Indigo(Proj||Work||whatever explicit)Dir) and initialize them with independent values.
What are you up to my friends ?
Note that the bigger instances should be in the other side in the final image.
bkircher
Post by bkircher » Wed Oct 31, 2007 4:40 am
just briefly:
Let's stick with one file containing all the prefs:
We could clear the script up by something like
global proc Bla ()
// edit these settings to your liking
$mti_InstallDir = "bla"; // path indigo is installed in
$mti_AlternativeInstallDir = "blaBla"; // alternative path indigo is installed in, e.g. local)
All settings should be contained in the mti_settings, so they can be editied/accessed within maya.
This is making very good progress!
p.s.:
Let's discuss about the best preferences, we do can deviate from the indigo defaults if that leads to a less noisy image, what do you think?
Post by CTZn » Wed Oct 31, 2007 5:23 am
I agree for the settings to be written to a file.
As for "improved" settings, well I'm not sure but I'll let you do for now bkircher if I may. That's a subjective/context-dependent topic and that's why my opinion is reserved.
On clamped values again: I suggest we clamp the slider but not the value itself as long as Indigo can take it, would like to have your opinion on that but really that's bugging me :?
Urgent work finished (waiting for feedback), will commit fixes within 6 hours !
Post by CTZn » Wed Oct 31, 2007 6:13 am
REV 39
Fixed: instances z flip when y is up.
now on rot matrices ! Did you get them working bkircher ?
dougal2
Post by dougal2 » Wed Oct 31, 2007 6:24 am
REV 40
implemented saving indigo paths to file.
upon first load the defaults are saved, but for now
mti_SavePathsToFile; needs to be called to update the file. changes are not automatically saved. we need a GUI button.
