lego
by lego » Mon Oct 16, 2006 12:34 am
wow thank you! very fast
p.s. sei italiano?
leope
by leope » Mon Oct 16, 2006 12:47 am
Si', ce ne sono un sacco da queste parti
DaveC
by DaveC » Mon Oct 16, 2006 2:47 am
Thank you
Kachu
by Kachu » Mon Oct 16, 2006 2:08 pm
Good job with the nk fix. And adding the Burn parameter setting.
My renders seem to be coming out too white. Whats a good whiteballance setting to use?
Also is there a way to set the temprature of lights in blender or do I need to manually edit that.
afecelis
by afecelis » Mon Oct 16, 2006 3:18 pm
leope, ten million thanks!
balder
by balder » Tue Oct 17, 2006 5:14 am
Xtra-cool!
(grazie, presumendo tu m'intenda)
lego
by lego » Fri Oct 20, 2006 3:53 am
I think that there's a bug while exporting an object with multiple materials, with one of these being an emitter
I lost two hours today with this problem
I think that the emitter material is exporter as a non emitting one
zuegs
by zuegs » Fri Oct 20, 2006 5:16 am
hi lego, meshlights works only for complete mesh. The first assigned material defines if it's a meshlight or not. For non-emitting meshes you can assign different materials for different faces (i think
You can separate the emitting faces in a new object and assign a light material to it...
regards zuegs
Users browsing this forum: DotBot [Bot] and 48 guests
