Schott Glass Material Library for Indigo 1.0.1+ * Updated *
WytRaven
Post by WytRaven » Sun Oct 21, 2007 8:57 am
Updated
Here is the final version of the Schott Glass Material Library complete with previews of every single material (approximately 8 days of rendering without pause).
Click here to download the library - includes a fix for one missing material and another incorrectly named
You can directly include this file into any .igs using the following code:
<include>
   <pathname>SomePath/SchottGlassMaterialLibrary.igml</pathname>
</include>
You can also use the included catalog PDF to make it easier to select a particular glass that might suit your requirements. There is one material per glass and the materials are named exactly as the glasses are so SF57 in the catalog = material name SF57 in the library.
This library will only work with Indigo version 1.0.1 and above as it uses the new tabulated data tag.
Previews:
Size reference: Sphere has a 5cm diameter and the pane is 5cm x 5cm x 0.5cm.
Each rendered to 5000spp:
SF57 Test rendered to 16000 samples/pixel
Post by Zom-B » Sun Oct 21, 2007 9:11 am
wow.... great work, not I get an Idea what this new function may be good for :)
So now tell me what glass could I take for a nice vase, a wine glass, a cola bottle or even a car window :?: :?: :?:
or is this library only "correct" for special prisms, lenses etc. ...
Maybe there exists an overall usable glass that looks nice/correct for everything?
Post by Kram1032 » Sun Oct 21, 2007 9:13 am
http://www.schott.com/ - you might find it, here ;)
WytRaven
Post by WytRaven » Sun Oct 21, 2007 9:18 am
I am currently running a test of SF57 on my crystal glass object as it looks from it's values to be a 'crystal' type glass; it contains lead and has a high base IoR, So far the test is looking pretty damn nice :)
I can't tell you off the top of my head exactly what to pick. I've done the hard work of converting this data to indigo materials now you can do the hard work of figuring out which one is best for what ;)
But basically if you are looking for a window glass then you would want one with a relatively low base IoR and high/uniform transmittance across the spectrum.
Post by Zom-B » Sun Oct 21, 2007 9:19 am
Kram1032 wrote:http://www.schott.com/ - you might find it, here ;)
This glass stuff is so special... I've never known of most stuff their glass is used for.
Perhaps I should stay at using specular etc. it the classic way :roll:
Post by Kram1032 » Sun Oct 21, 2007 9:22 am
window: low green absorption, quite high (relative to the green absorption, so, it's still low) blue.
red somewhere in between.
IoR 1.45-1.55 :)
CoolColJ
Post by CoolColJ » Sun Oct 21, 2007 10:09 am
WytRaven
thanks man, appreciate the effort!
zsouthboy
Post by zsouthboy » Sun Oct 21, 2007 12:23 pm
Totally agree, thanks for putting this together. I don't know if I'll use it for any of my stuff, but the option remains :D
CoolColJ
Post by CoolColJ » Sun Oct 21, 2007 12:37 pm
now how to get exporters to support these new tabulated format....?
zsouthboy
Post by zsouthboy » Sun Oct 21, 2007 12:40 pm
i was hoping we'd set it up to be as easy as specifying an .nk file is right now, myself
kc1
Post by kc1 » Sun Oct 21, 2007 10:01 pm
a source of tabulated spectra materials in radiance mgf format.
http://radsite.lbl.gov/mgf/materials.html
For explanations on format: http://local.wasp.uwa.edu.au/~pbourke/d ... html#begin
for example:
c Small_magenta_flower_(from_vine) =
cspec 400 700 0.0788 0.1019 0.1203 0.131 0.1352 0.1363 0.1311 \
0.1206 0.1051 0.0895 0.0762 0.0663 0.0576 0.0516 0.0483 \
0.0472 0.0478 0.051 0.0576 0.071 0.0952 0.1278 0.1593 \
0.1859 0.2109 0.2392 0.2672 0.2794 0.2966 0.3603 0.436
m Small_magenta_flower_(from_vine) =
rd 0.0777697
can be converted to:
<regular_tabulated>
<start_wavelength>0.4E-06</start_wavelength>
<end_wavelength>0.7E-06</end_wavelength>
<num_values>31</num_values>
<values>
0.0788 0.1019 0.1203 0.131 0.1352 0.1363 0.1311 0.1206 0.1051 0.0895 0.0762 0.0663 0.0576 0.0516 0.0483 0.0472 0.0478 0.051 0.0576 0.071 0.0952 0.1278 0.1593 0.1859 0.2109 0.2392 0.2672 0.2794 0.2966 0.3603 0.436
</values>
</regular_tabulated>
I don't know how convert rd (diffuse reflectance) in Indigo, maybe phong IOR
search on google for radiance mgf for others...
WytRaven
Post by WytRaven » Mon Oct 22, 2007 8:49 pm
SF57 test added to original post... It's a terrible 'shot' I know but it is just a test afterall. Screwed up the DoF big time :P Stupid DSCS315 camera... ;)
CoolColJ
Post by CoolColJ » Mon Oct 22, 2007 9:02 pm
that actually looks good to me :)
I guess your just too familiar with the render to appreciate it :D
Happens to me too...
Post by OnoSendai » Mon Oct 22, 2007 9:04 pm
That render u added to the post ROCKS!
please upload to gallery!
Post by Kram1032 » Tue Oct 23, 2007 12:23 am
those light lines O.o amazing caustics!!! That's great!!! Oh, and also those great reflections and refractions of the dices O.o really a great material :)
