Indigo 1.0.1
Indigo 1.0.1
Post by OnoSendai » Sun Oct 21, 2007 1:27 am
http://www.indigorenderer.com/joomla/in ... &Itemid=62
1.0.1
* added camera tone mapping
* added regular_tabulated spectrum type.
Camera tone mapping is an attempt to model the image generation process of a digital camera, and shares some parameters with a real camera.
ev_adjust is exposure-value adjustment; increasing this value by 1 will effectively double the 'sensor output'.
film speed (film ISO) has much the same effect, except it's a linear factor. Doubling the film ISO will double the 'sensor output'.
The response function uses data from
http://www1.cs.columbia.edu/CAVE/softwa ... b/dorf.php
, as such many cameras should be able to be modelled.
There is a calibration constant in the code that relates incident energy density on the sensor to the value input to the response function; this constant was determined thanks to some test images from Carbon.
I still need some more test scenes to make sure the whole camera tone mapping model is correct however.
How to use camera tone mapping:
<tonemapping>
		<camera>
			<ev_adjust>0.0</ev_adjust>
			<film_iso>100.0</film_iso>
			<response_function_path>data/camera_response_functions/dscs315.txt</response_function_path>
		</camera>
	</tonemapping>
The regular_tabulated spectrum type allows (nearly) arbitrary spectra to be defined in the scene file.
How to use regular tabulated spectrum type:
	<material>
		<name>mat1</name>
		<diffuse>
			<albedo_spectrum>
				<regular_tabulated>
					<start_wavelength>0.4E-06</start_wavelength>
					<end_wavelength>0.7E-06</end_wavelength>
					<num_values>10</num_values>
					<values>
						1 0.9 0.5 0.345 0 0 0 0 0 0
					</values>
				</regular_tabulated>
			</albedo_spectrum>
		</diffuse>
	</material>
manitwo
Post by manitwo » Sun Oct 21, 2007 1:31 am
*awaytesting*
afecelis
Post by afecelis » Sun Oct 21, 2007 1:33 am
arrrggghhh! manitwo was faster! ;)
Thanks Ono! :D
Post by suvakas » Sun Oct 21, 2007 1:36 am
Great news!
I can now finally remove my pseudo ISO stuff from exporter and use the more real thing.
Thanks Ono!
Post by OnoSendai » Sun Oct 21, 2007 1:39 am
added more explanation.
matsta
Post by matsta » Sun Oct 21, 2007 1:43 am
Master Ono
much love. great speed and an awesome job!
carbon
Post by carbon » Sun Oct 21, 2007 1:43 am
:D
Kosmokrator
Post by Kosmokrator » Sun Oct 21, 2007 1:45 am
thnx a lot Ono!!
ciccio
Post by ciccio » Sun Oct 21, 2007 1:52 am
:shock: :shock: :D :shock:
Post by CTZn » Sun Oct 21, 2007 2:46 am
:shock: 1.01 ! A psychological threshold has been crossed... Argh, new tags !
Is the old cam (and tonemap) model still available ?
Post by Zom-B » Sun Oct 21, 2007 2:56 am
Great to see your first 1.x version so soon Ono :D
but I have a Problem using the regular_tabulated spectrum stuff :?
I copied&pasted the example code on a very simple scene file, and get following error_message:
SceneLoaderExcep: Syntax error while parsing data (In element 'regular_tabulated', around line 60, column 13)
Fatal Error: SceneLoaderExcep: Syntax error while parsing data (In element 'regular_tabulated', around line 60, column 13)
I attached my preview Scene to this post.
It also seems that specular material stilll don't like touching phong materials.
I did a long time render on 0.9t9 and in 1.0.1 it seems to become messed up the same way.
mat_preview_studio.igs
The simple Scene File having a Problem using the regular_tabulated spectrum stuff.
(2.45 KiB) Downloaded 454 times
Indigo 1.0.1 rendered for 10min -scaled down to 50%
Indigo 0.9t9 rendered for 5.40h - scaled down to 50%
Post by Kram1032 » Sun Oct 21, 2007 2:56 am
so, there's no 0.10txyz xD
great :D finally a "full" version of indigo :)
Post by OnoSendai » Sun Oct 21, 2007 3:05 am
ZomB:
You have to make sure you have 10 floating point values inside the <values> tag. You had 9, which i guess is my fault, since I had 9 in the example :)
What's the problem with ur pool scene?
Post by OnoSendai » Sun Oct 21, 2007 3:06 am
CTZn wrote::shock: 1.01 ! A psychological threshold has been crossed... Argh, new tags !
Yes old tonemapping modes are still usable.
Post by Kram1032 » Sun Oct 21, 2007 3:07 am
or you set the num-values to 9, I suppose?
(or you use even more values and set the num-values higher...)
Users browsing this forum: No registered users and 61 guests
