what software do you use to edit BIG xml files ?
- drBouvierLeduc
Well, everything is in the title.
I edit indigo's xml files with "notepad2" (a very powerfull freeware that replace windows's default notepad http://www.flos-freeware.ch/notepad2.html), but when I open files bigger than, let's say 50 mo, it takes forever to make a single modification.
So, do you know any software wich can handle BIG xml files (>50 mo) ?
- afecelis
Scite is totally awesome and supports a gazillion languages-scripts
It also works very well in combination with C++ compilers like gcc ; oh yes, and workflow won't change if you'r eon Linux or Windoze
johanjohan
- drBouvierLeduc
I´ve been using UltraEdit (syntax highlighting, good search & replace, macros, and a gazillion other functions) for many years now. Saves a 100 MB XML in about 1-2 secs, editing is real time.
http://www.ultraedit.com/
"Have you ever had a render Neo you were so sure was real? What if you couldn't wake from that render? How would you know the difference between the rendered world, and the real world?"
Notepad++ can collapse and expand XML tag trees. Handy.
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
