EDIT: Links removed. Final version for proof of concept further down below somewhere
Cut Crystal Tests
Here's version 5 with Sellmeier calculated IORs. This time around I have include the Office 2007 version of the sheet for those that have Office 2007 along with the Office 95-2003 version as well. I have no idea how the chart will show up in the .xls version...
Kram1032 wrote:...if you directly compare the results, is there any difference at all?
Hu, if I take a really close look, I think, sellmeier is slightly lower than the measured resultsAm I right?
Measured
1.79026 1.79539 1.80187 1.81185 1.81335
1.82038 1.83102 1.83650 1.83808 1.83957
1.84636 1.84666 1.85504 1.87204 1.87425
1.89393 1.91366
Cauchy
1.79621 1.79756 1.80072 1.80933 1.81087
1.81840 1.83005 1.83598 1.83766 1.83924
1.84636 1.84668 1.85518 1.87152 1.87355
1.89074 1.90642
Sellmeier
1.89393 1.91366
Well... So much for me modelling my crystal plates this weekend *sigh*
I'm off to bed got work in the morning
Ok Kram just for you...
Render @ 57 hours (JPEG compressed) 50% scale: Click for full res PNG
Well here's the problem. I still don't know what you are using for the A coefficient in your Cauchy calculations, we can only provide a B coefficient so you must be calculating A from something. I am using nD in mine and calculating the B coefficient as the gradient of a line between nF and nC. Without knowing how your coming up with your A it makes it hard to fine tune my B values.
This evening I will setup that chart so that I can select a glass from the list and it will display the selected data. That will facilitate easier adjustment of the B coefficients because I will be able to see the changes as I make them.
If only there were a way to derive Cauchy Coefficients from Sellmeier coefficients
Lol. Well the image doesn't directly relate to the technical stuff rather the technical stuff was inspired by the image.
The 'crystal' material in the image is hacked from an IOR of 2 and a Cauchy B calculated from Heavy Flint glass IORs at the F and C wavelengths so it's not accurate at all. But it does look mighty pretty doesn't it
Good news. We now have n/ɑ pairs from 780nm - 350nm in 10nm steps.
Index of refraction values calculated via Sellmeier's equations.
Absorption coefficients were calculated by applying a spline function to the meassured values and performing intercepts on the curve at the desired locations.
I have setup a live charting system whereby I can adjust the B coefficients gradually and see the results visually instantly. I will tune them as best I can later.
Ono is there any particular reason why you just seem to refuse point blank to answer the question of how you calculate your Cauchy A values internally?
Render is now @ ~83h and ~5550 samples/pixel.
great
I'm not sure, if he absolutely refuses, but sometimes, it's really hard to get an answer, out of him, especially, if it's indigo-internal-techniques related xD
Might be related to something like wanting to have free time, when looking through the forums, and not needing to think about Indigo's calcs, for some mo's
