Blendigo for v0.9
Post by Kram1032 » Sun Oct 07, 2007 11:13 am
[REQ] for both versions of Blendigo:
non-uniformal henyey-greenstein g-values :)
[REQ] to Ono: explain, what that exactly does xD
Big Fan
Post by Big Fan » Sun Oct 07, 2007 11:55 am
well i already told you I wont be doing that and why elsewhere :wink:
EDIT ok kram wins after heavy weight discussion :roll: henyey-greenstein is now rgb see previous script post for update
Post by Kram1032 » Sun Oct 07, 2007 8:49 pm
lol, actually, the discussion wasn't heavy at all :P
Anyway, thank you, very much :D
WytRaven
Post by WytRaven » Sun Oct 07, 2007 9:07 pm
Thx BigFan, saves me hand editing it in the igs all the time :)
Post by Kram1032 » Sun Oct 07, 2007 10:48 pm
ok.
Following problems:
My glossy transparent SSS and rgb-g-value thingy didn't get exported!
Far less important "problem": The ray nudge distance got exported slightly wrong... after about 5 unneeded "0", it added 149 at the end of the thing... some precession error?
The rest appears to be fine :)
The mat didn't only have no g-value, btw, but it simply got fully ignored :?
That causes the export progress, finishing without any bug, but then, Indigo writes "Material.003 isn't defined" and closes a nanosec later, so that it was really hard to read, what's wrong^^
Big Fan
Post by Big Fan » Sun Oct 07, 2007 11:21 pm
well I just tried glossy transparent here and it seemed to work ok kram so perhaps you missed setting it somehow?
if there is a problem it would help to know more - can you post your material or something
I am aware of the 149 not sure where that comes from presently but it is very small error so I leave it at the moment
Post by Kram1032 » Sun Oct 07, 2007 11:26 pm
I'm not sure, what's the problem, now....
I noticed, that I put the material on the object instead of the mesh, but even after changing, it still didn't work...
I also tried to use different material typed...
I guess, that such a "noone knows, how or why, but it never'll show up again"-bug... I'm pretty sure, when I rebuild it, it's gone...
If it still doesn't work after rebuilding, I'll post my mat :)
Post by Kram1032 » Sun Oct 07, 2007 11:47 pm
ok, bug tracked!
I think, the problem occurs, when you define a material ONLY on a sphere primitive.
If you use it twice, I bet, it works just fine.
sk2k
Post by sk2k » Mon Oct 08, 2007 3:03 am
@bf
Do you changed the calculation for the aperture radius? I get much darker pictures with your t8 exporter so i looked into the exported .igs files to see what's the difference. With the previous t7 exporter i get <aperture_radius>0.005617</aperture_radius>. With your new exporter i get <aperture_radius>0.054894</aperture_radius>.
MfG
sk2k
Post by Kram1032 » Mon Oct 08, 2007 3:12 am
he changed the DoF export way and DoF is directly related to the aperture size^^
but ten times larger apertude? xD
Big Fan
Post by Big Fan » Mon Oct 08, 2007 6:15 pm
ok so sorry for the delay posting a response.
well yes it is 'different' than previous.
when zeugs did this before he wasn't sure if he had done it correctly.
I think you will find he had some unusual values as well.
I have gone about this a different way but I will take a look at what I did again...
the trouble was that the rendered dof effect wasn't strong enough using realistic aperture values and the estimated dof wasn't agreeing with the rendered image either - I have reasonable confidence in the dof calcs being sound.
I set in place calc to generate 0.8mm-5.8mm radius for f64-f1.2 which I think is reasonable but somehow this doesn't equate to a realistic looking blur when rendered.
so there is a fudge factor of 8.6 ( my best estimate) in there ATM - I have asked ono about this discrepency...
possibly you should ask yourself if the image looks correct at this point rather than be too concerned that the values are different.. but as I say I will take a look at it again.
please remember this is my variant WIP I give you to test its not 'the' official exporter
neepneep
Post by neepneep » Tue Oct 09, 2007 6:41 am
INDIGO EXPORT
Object Ground in layer 2
Object Grass in layer 2
Object Empty in layer 1
Object Camera in layer 1
Object Sun in layer 1
processing DupObject "Ground"...
  File "<string>", line 2561, in buttonEvt
  File "<string>", line 1962, in exportStill
  File "<string>", line 1933, in export
  File "<string>", line 1624, in exportObjects
  File "<string>", line 1610, in exportObject
TypeError: exportObject() takes exactly 5 arguments (4 given)
I am trying to duplivert/instance a blade of grass onto a static particle emitting plane.
It don't work :(
Post by BbB » Tue Oct 09, 2007 10:16 am
Hi BigFan. Sorry but I missed the link. I looked and when I looked again it was gone. Could you post it for a second so that I can grab it before it is gone again?
Big Fan
Post by Big Fan » Tue Oct 09, 2007 5:55 pm
@neepneep
which exporter version is that you are using?
also what do you mean about 'a static particle emitting plane' ?
the script doesnt handle Blender particles...sorry
if you want to do particles you are going to have to make the particles into meshes somehow... apparently there is a script around somewhere in the blender community for that
@BbB
in your pm
Post by BbB » Tue Oct 09, 2007 6:32 pm
Thanks a zillion BF
Users browsing this forum: Bing [Bot] and 41 guests
