little test
little test
Hi friends, a little test whit Indigo and Maxwell
- out.jpg (394.3 KiB) Viewed 2401 times
in tests, everything should be as similar as possible!
the DoF *might* be hard to get similar (not sure about that) but the mugs definitely should be coloured similar^^
is the white on the pencil-mug similar? Indigo's is a lot brighter O.o - might be tone mapping related, which is hard to get similar, for sure...
Maxwell's highlights on the screwed thingy are far brighter than indigo's... also tone mapping related? On those highlights, you clearly can see Aliasing in the Maxwell render
similar time? If so, that was an other hint on Indigo being faster than Maxwell
lol, I'm sorry, I can't see, what you've fixed on the pencil^^
I meant, the peaky part of the pencil in the foreground:
the yellow texture shouldn't go over the edge! think of it: a sharpener would get rid of the yellow colour. the wood would start to show though.
oh and the graphite still doesn't look shiny enough^^
