Cut Crystal Tests
Post by OnoSendai » Sun Oct 07, 2007 5:54 pm
Building some super-realistic glass materials from the Schott data sounds like a cool idea :)
Here's how I recommend you calculate the absorption coefficent (which in general varies with the wavelength) from the given data:
the transmittance when passing a distance d through a uniform (and non-scattering) medium is given by
t = exp(-a*d)
where a is the absorption coefficient (sometimes written as sigma subscript a), d is the distance travelled through the medium, and t is the transmittance.
Let's use units of metres here, so d = distance in meters, and a has units of m^-1.
When using the Schott data, I suggest you use the transmittance value at 25mm instead of the 10mm value, because it will give more precise results considering we only have 3 sig figs.
Lets take the example of the glass N-LAF33, (page 58 ) at 370nm.
The 25mm transmittance is 0.680.
Plugging that into the above equation (using d = 0.025m), rearranged as
a = -ln(t) / d
gives a = 15.426m^-1. You can check that it works for d = 10mm as well.
Note that ln() is the base-e logarithm, not the base 10 logarithm.
So we now have a value for the absorption coefficient at 370nm.
Now the question is how to pass this (wavelength varying) data to Indigo.
The best way would be able to pass in a table of (wavelength, absorption coefficient) pairs. Indigo can't currently accept data like this, but the code exists to handle such tables internally.
So what I'll do is to code in a new spectrum XML type that can handle tabulated data like this.
WytRaven
Post by WytRaven » Sun Oct 07, 2007 7:12 pm
Thank you very much for your replies Ono and I am very pleased that you are suportive of this idea. It's going to take my math deficient mind the rest of the weekend to absorb everything you have written here but I will get it eventually ;)
In the mean time I will use the information you have provided to calculate absorption coeficients from 1060nm down to 390nm using the 25mm measurements in preparation for the additions to indigo :)
I will also reformat the spreadsheet in a way that is more conducive with saving out to .xls and next time I upload it it will come with all the formulas and Schott data intact instead of providing a values only version.
Post by OnoSendai » Sun Oct 07, 2007 7:15 pm
btw, since we're only interested in the visible wavelengths, a range of about 350 - 800nm should suffice, but extra values won't hurt.
Post by Kram1032 » Sun Oct 07, 2007 7:23 pm
wow :D
finally Indigo get's transparent nk's :D:D
WytRaven
Post by WytRaven » Sun Oct 07, 2007 8:57 pm
Ok new version of the spreadsheet with all data/formulas intact. Absorption values have been calculated from 1060nm to 350nm with a couple of conditions:
  • Some transmission data was equal to zero, the log function doesn't like zero so all zeroes were replaced with 1^-307 (the smallest possible non-zero number Excel can handle)
  • Not all data was present that low down the spectrum; absent data was replaced with 1^-307. Data created marked with red background in source list
EDIT: Link Removed
CoolColJ
Post by CoolColJ » Sun Oct 07, 2007 9:36 pm
what can I use to read the data that's free?
So I guess these will be turned into some form of NK file for future Indigo version?
WytRaven
Post by WytRaven » Sun Oct 07, 2007 10:05 pm
Ok IOR and Absorption pairs now. Still uses old Cauchy B calculation until I can figure out a better way to do it.
EDIT: Link removed, see further down for new version.
CoolColJ
Post by CoolColJ » Sun Oct 07, 2007 11:34 pm
not the archive itself, I can unpack it with Winrar just fine, but read the file itself :)
WytRaven
Post by WytRaven » Sun Oct 07, 2007 11:46 pm
Here's a chart I just built to compare the Cauchy calculated IOR's vs the meassured IORs. Looks like the current Cauchy B calculation is just fine:
WytRaven
Post by WytRaven » Sun Oct 07, 2007 11:47 pm
CoolColJ wrote:not the archive itself, I can unpack it with Winrar just fine, but read the file itself :)
It's jsut a standard Office 97-2003 Excel spreadsheet. If you aren't on windows and/or don't have MS Office then I guess something like Open Office would be a good start?
Post by OnoSendai » Sun Oct 07, 2007 11:49 pm
Interesting graph.
Can we see it replotted, with wavelength linearly increasing along the horizontal axis?
Post by Kram1032 » Mon Oct 08, 2007 12:00 am
selmeyer's is supposed to be correct, even in invisible spectrum, where as caughy's is slowly getting incorrect-ish on the graph's borders :D that's clearly shown in this graph :) (the caughy part, at least... as selmeyer wasn't used, here...
WytRaven
Post by WytRaven » Mon Oct 08, 2007 12:43 am
Linear wavelength:
WytRaven
Post by WytRaven » Mon Oct 08, 2007 1:36 am
Added in Sellmeier, needless to say I am now in the process of recalculating the IOR portion of the n/ɑ pairs using Sellmeier :P
You can't even see the measured data anymore it's that well covered by the Sellmeier :twisted:
Post by Kram1032 » Mon Oct 08, 2007 1:43 am
far more exact :D
just as I said
(based on Wikipedia lol)
if you directly compare the results, is there any difference at all?
Hu, if I take a really close look, I think, sellmeier is slightly lower than the measured results :) Am I right?
