How to use .igs files
5 posts • Page 1 of 1
mcgrathfx
Post by mcgrathfx » Sun Oct 07, 2007 10:33 am
Hello,
A newby here - I searched the forums but couldn't find my answer:
How does one use .igs files? I see all the .igs files in the test scenes folder
in my Indigo directory, but I can't seem to find any info on how to use these scenes. :? I am using Indigo 08 stable and Blendigo 08t2 beta 1d.
PS: Indigo Rocks!
CoolColJ
Post by CoolColJ » Sun Oct 07, 2007 10:52 am
just run the indigo.exe and open the files with it
the render size is set in the ini file, and the renders will be saved in the render folder
mcgrathfx
Post by mcgrathfx » Sun Oct 07, 2007 11:00 am
Thanks CoolColJ! That was too easy - I should have figured it out myself.
You can probably tell this is my first endeavor with an external renderer. :)
hafunui
Post by hafunui » Sun Oct 07, 2007 12:20 pm
You can also open them up in a text editor to tweak settings manually.
mcgrathfx
Post by mcgrathfx » Sun Oct 07, 2007 2:04 pm
Hi Hafunui,
Thanks for this info also - I did open Indigo's .ini file to see about changing the render size as per CoolColJ's post. Glad to hear you can edit
the .igs file also. I'm having too much fun with this renderer! Michael :D
Users browsing this forum: Baidu [Spider] and 56 guests
