[Anim] Pencil in vase
11 posts • Page 1 of 1
zsouthboy
Post by zsouthboy » Thu Sep 27, 2007 7:52 am
http://www.zsouthboy.com/indigo_animation.swf
.swf format because: A) Everyone has flash and B) It actually embeds the full .pngs that I rendered inside - no quality loss (like GIF - blech)
Attached is a .png preview.
Note that it looks like FF and IE maximize a flash file automatically when you play it - un maximize your browser for a better viewing.
EDIT: File is ~17 MB in size - you might be better off downloading the file and "viewing" it in FF or IE (use "Open With..")
Frame 1
DaveC
Post by DaveC » Thu Sep 27, 2007 8:04 am
That is pretty sweeeeet. It would look great if the vase was rotating. Geez, look at that. Two animations done with Indigo in one day :D:D
Post by Kram1032 » Thu Sep 27, 2007 8:07 am
Wow!
That's great :D
Btw, it's not that easy, to say "everyone has flash"...
As Far as I know, there are some linux6flash problems with some distros...
dunno, exactly, though...
zsouthboy
Post by zsouthboy » Thu Sep 27, 2007 8:18 am
Forgot to add render parameters:
8 hours for all 19 frames - so whatever amount of time that is per frame, on Quad 2.4ghz - MLT, BD, and Hybrid on - Max Consec Rejec at 1000, Ray Bounces at 10000. Ubuntu Gutsy Tribe 5 x64.
I ended up writing a small bash script to automate / render the animation for me, as clicking "animate" in Blendigo doesn't work in Linux.
@all: thanks for the kind words!
EDIT: forgot to say - Thanks StompinTom for his studio setup .blend!
DaveC
Post by DaveC » Thu Sep 27, 2007 9:10 am
Exactly how did you get Indigo to work in Ubuntu 64 bit? That's great.
zsouthboy
Post by zsouthboy » Thu Sep 27, 2007 9:19 am
DaveC wrote:Exactly how did you get Indigo to work in Ubuntu 64 bit? That's great.
Indigo 32-bit works fine in Wine.
64-bit works for some, too - not me - gives me an invalid PE error.
DaveC
Post by DaveC » Thu Sep 27, 2007 9:30 am
What I meant was, I didn't think you could use wine in 64 bit linux in order to use indigo. Or am I just being the usual linux-noob that I always am?! :S
zsouthboy
Post by zsouthboy » Thu Sep 27, 2007 11:18 am
64-bit linux is compatible with 32-bit programs perfectly. :)
Macrob
Post by Macrob » Thu Sep 27, 2007 7:22 pm
zsouthboy wrote:64-bit linux is compatible with 32-bit programs perfectly. :)
Not exactly.
http://www.gentoo.org/doc/en/gentoo-amd ... l#multilib
If you run a pure 64bit-environment, you can not run 32-bit programs.
But I don´t know if the other linux distributions (e.g ubuntu, ...) offer pure 64bit environments :?:
zsouthboy
Post by zsouthboy » Fri Sep 28, 2007 1:50 am
if you install 32-bit libraries, you can run 32-bit programs.
They run perfectly.
The majority of programs on linux are open source, and are therefore compiled for your target platform - which means 64-bit only isn't a problem, if that is what you want to run.
Post by Kram1032 » Fri Sep 28, 2007 3:25 am
Dave didn't manage to install wine.
He needs help
That's what he meant.
