[REQ] Comments in rendered images
Post by OnoSendai » Wed Sep 19, 2007 6:38 am
zsouthboy wrote:Any half-decent image editor should allow you to view the extra information.
Can't see it in any of the ones I've tried, including the Gimp, which is certainly half-decent.
Post by Zom-B » Wed Sep 19, 2007 7:47 am
OnoSendai wrote:Can't see it in any of the ones I've tried, including the Gimp, which is certainly half-decent.
Gimp supports EXIF display since v2.3.9.... simply try using recent 2.4.0 RC2
CoolColJ
Post by CoolColJ » Wed Sep 19, 2007 9:00 am
what about ACDSEE or the older versions?
I use it's thumbnail browser a lot. Shows lots of Exif data
Maybe even Window's thumbnail view with right click properties? It normally shows quite a bit of info. Even hovering the mouse over photos I've taken will show what camera was used to take it etc and then right click will show everything including exposure
IanC
Post by IanC » Wed Sep 19, 2007 12:22 pm
In Gimp, it's view->info window, or ctrl-shift-i
That lets you read the comments in exif data, anyway.
In kde 3.5, you can see the meta data by right clicking on it.
Post by OnoSendai » Wed Sep 19, 2007 3:20 pm
it's not EXIF data though.
IanC
Post by IanC » Thu Sep 20, 2007 12:44 pm
It is the comments in the exif data, if you want to first check you're writing properly to the files.
Or you could download infranview, I know that will show exif data (press e I think). http://www.irfanview.com/
Post by OnoSendai » Mon Sep 24, 2007 4:55 am
IanC wrote:It is the comments in the exif data, if you want to first check you're writing properly to the files.
It's not Exif comments either.
The only half-decent solution I can think of is to add a little command-line switch to indigo, that will dump all metadata out of a specified PNG file.
e.g.
indigo_console.exe --showmetadata renders/im456456.png
render time: 456456s
samples per pixel: 45654
Post by Kram1032 » Mon Sep 24, 2007 5:24 am
what the hell IS exif, then? xD
Heavily Tessellated
Post by Heavily Tessellated » Mon Sep 24, 2007 5:35 am
http://pmt.sourceforge.net/pngmeta/
The PNG & MNG Tools set has pngmeta, which is probably much like what you envision for the --flag extracting of said fields... if you don't want to add the display code to the indigo executable, we could just send people there...
Alternatively there are precompiled binaries for Windows and linux here: http://www.libpng.org/pub/png/apps/pngmeta.html
and yep, gimp-2.2.15 seems to only reads comment, no additional fields - and apparently only reads it's -own- comments; trying the PNG samples from the above toolkit, it reads nothing! Weird, that.
IanC
Post by IanC » Mon Oct 01, 2007 12:14 am
OnoSendai wrote: It's not Exif comments either.
Really? Because I'm setting the "JPEG Exif comments" in kde, and they are appearing in GIMP under 'comments'.
Not for me, see the attached image. [edit removed beacuse it's huge, will compress and re-up] [edit 2: re-upped]
Heavily Tessellated
Post by Heavily Tessellated » Mon Oct 01, 2007 5:00 am
Uhm that's gimp, but what did you set the comment with? If you set it with gimp, yes, gimp will read it back. That's what "it's -own- comments" meant. Try to set it with another app, perhaps ImageMagick, then open it in gimp - the Image Information window will go dumb and show nothing...
nonetheless if nik feels like adding PNG tEXt tag:value pairs the proper way, I'm sure we'll be able to extract said data one way or another. But not with gimp, for now anyway.
Post by OnoSendai » Mon Oct 01, 2007 9:42 pm
Ok, i've added this feature.
Will be available in next indigo test.
the information is extracted like this:
PS C:\programming\indigo\trunk\indigo_x86> .\indigo_console.exe --dumpmetadata 'C:\programming\indigo\trunk\indigo_x86\r
enders\im1191231596.png'
Indigo Renderer v0.9 test 8, Windows 32-bit Debug build.
SSE present.
SSE2 present.
SSE3 present.
------------ Metadata --------------
Indigo version used: Indigo Renderer v0.9 test 8, Windows 32-bit Debug build.
bidirectional: 1
height: 450
hybrid: 0
large_mutation_prob: 0.40000
max_change: 0.01000
max_num_consec_rejections: 1000
maxdepth: 10000
metropolis: 0
num_samples: 200000.00000
num_threads: 3
ray_origin_nudge_distance: 0.00001
render time elapsed: 13.07560
samples_per_pixel: 0.74074
samples_per_sec: 15295.66058
scene_file_path: C:\programming\models\testscenes\specular_sphere_test.igs
super_sample_factor: 1
width: 600
CoolColJ
Post by CoolColJ » Mon Oct 01, 2007 10:13 pm
great, that will be very handy
Post by Kram1032 » Tue Oct 02, 2007 1:40 am
Great :D
@ Heavily:
IanC wrote:I'm setting the "JPEG Exif comments" in kde
IanC
Post by IanC » Tue Oct 02, 2007 6:06 am
Cool, cheers Nick.
Kram, thanks :)
HT, as Kram points out, I did it in KDE. That's what 'in kde' means :p
Users browsing this forum: Google [Bot] and 62 guests
