Indigo 0.9 test 7
Indigo 0.9 test 7
32 bit version:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
64 bit version:
This release pretty much focused on performance and correctness. I spent a lot of time refactoring and improving the bidir code, both in terms of structure and performance.
Cornell box test now renders at approximately 38Ksamples/second (single thread), up from about 28Ksamples/second in 0.9 test 6.
Changelog:
0.9 test 7
* fixed bug with containing media for lights.
* raise error on re-used mesh name
* changed specular BSDF *again*
* fixed diffuse transmitter to avoid noise.
* changed reinhard tonemapping for better contrast on LDR images
* speedups / refactor for bidir code.
* more efficient sampling for participating media / SSS
* some correctness fixes for participating media / SSS
As per usual, let me know of any bugs you spot!
EDIT: updated 32 bit link to version where OpenEXR support is enabled.
64 bit version:
Changelog:
0.9 test 7
Lord of the Rings Junkie
wooooo!
big performance improvements in my new pool render tests
24000 samples and 45+ micro-seconds / sample
now
31000 samples/second 31+ micro-seconds / sample
I have never hit over 25,000 samples before with Bidirectional MLT even in simple scenes
BTW, Ono have you fixed the sun position change when using Bidirectional MLT compared to MLT?
now
- Heavily Tessellated
well, from the wine front, it's a mixed bag. The defaults like ior_test.igs runs 20% faster or more, but on the two scenes I'm currently working on (both heavy glass and refl use) it's about the same or even slower (one is 250us/sample on test6, to 270us/sample on test7)
Also a weird change, did you defer the text writes as part of the speed improvements? The console output comes up a character at a time! It's reminiscent of chatting on a 9600 baud modem. This is the exact same wine setup, but I'd like to hear other wine users...
thanks Ono!!
i also get strange speed results (winXP 32bit):
a very basic scene renders faster (90000 to 135000 samples/sec), but a scene with .exr lighting, a glass and a liquid gives this result:
09 test 6: 16000+ samples/sec
09 test 7.2: starts with 9000, then goes down to 8000..
will test it further..
Ciao!!
Marco
Ciao!!
Marco
Thanks Master Ono for this great SpeedUp release!!!
I did 2 comparison rendering between 0.9t6 & 0.9t7 each for 5 min:
dof_test.igs +31% samples / second
empty.igs +46% samples / secondpolygonmanufaktur.de
Users browsing this forum: No registered users and 103 guests
