CoolColJ's test pics thread
Heavily Tessellated
Post by Heavily Tessellated » Tue Sep 11, 2007 3:24 pm
We need to pool together and give CCJ solo access to our yet-to-be-built Indigo cluster in the wee hours, this fool NEEDS a couple teraflops available at all times. :D
BTW, thanks for that http://www.cs.huji.ac.il/~danix/itm/ link, got lost there for a good half hour. (and not for nothin' but that spatially varying blur is as tricky/slick as the tonemapping tactics. DoF in post that looks as good as rendered? :gasp: )
CoolColJ
Post by CoolColJ » Tue Sep 11, 2007 3:45 pm
yes please!!!!! :twisted:
I discovered something....
This scene I'm did to compare to Fry. I did 2 renders, one with a ground plane (same for Fry) and one without a ground plane outside of the view, or pool in this case. Huge difference in render times. And this brings Indigo's render time inline with Fry. I suspect Fry removes all geometry not in view from the calculations automaticly!
Because at the same render time, Indigo and Fry are neck to neck sample count wise, with 20million samples a piece at the 47 minute mark.
Removing the big ground plane outside of the view brought about massive differences in the render times to results ratio.... :shock:
The sample rate is exactly the same as well, and I used Bidirectional MLT
2nd one is still dark from the supersampling, but man the caustics are all there very quickly! The first one was developing caustics dot by dot :?
maybe Indigo's engine needs some sorting in this area ;)
No ground plane....and only 6mins render time...
with ground plane... after 4+ hours!!!!
CoolColJ
Post by CoolColJ » Tue Sep 11, 2007 4:09 pm
actually the pic is still dark after more rendering, and with different overall colours...
so even with the same tone mapping settings the pic is rendering differently without the ground plane, not just speed wise!
Post by OnoSendai » Wed Sep 12, 2007 12:16 am
This is expected with bidirectional path tracing.
When you have a large plane, rays are cast from the sky to all positions on the plane. Therefore the chance of the ray hitting the surface of the pool, and then making a nice caustic path, is much less than if there is not a big plane under the pool.
So, when using bidir path tracing / bidir mlt, try and make the size of the scene not much bigger than the 'interesting' portion of the scene - i.e. the volume you will be looking at directly.
Post by OnoSendai » Wed Sep 12, 2007 12:21 am
CoolColJ wrote:actually the pic is still dark after more rendering, and with different overall colours...
If it converges to a different result, it's a bug.
Can you post the scene, or email it to me?
Just the one version as an .igs should do, I can comment in/out the ground plane.
CoolColJ
Post by CoolColJ » Wed Sep 12, 2007 10:18 am
Only problem is, the scene is 90megs :)
The water mesh is pretty big
it does compress well though - 16.9 megs after zip compression
I'll try and host it somewhere
Post by OnoSendai » Wed Sep 12, 2007 9:03 pm
Thanks for the scene.
Btw, the water mesh is building with a BIH, if you increase the tri threshold so it builds with a kd-tree, it renders about twice as fast.
CoolColJ
Post by CoolColJ » Wed Sep 12, 2007 11:22 pm
OnoSendai wrote:Thanks for the scene.
thanks
your right! samples per second jumps from under 7000 to 13,000+
micro-seconds / sample drops from high 100s to the 70s :shock:
I guess I should set my "bih_tri_threshold" to 800000
Post by OnoSendai » Thu Sep 13, 2007 12:54 am
Yeah,
perhaps I should bump up the default threshold, esp. since kd-tree building is a lot faster now.
surreal
Post by surreal » Thu Sep 13, 2007 9:18 am
Hey, if you need a spot to host any files (Size doesn't matter to me to much) I got tonnes of bandwidth and space to use up!
CoolColJ
Post by CoolColJ » Thu Sep 13, 2007 10:12 am
surreal wrote:Hey, if you need a spot to host any files (Size doesn't matter to me to much) I got tonnes of bandwidth and space to use up!
thanks for the offer, I'll keep it in mind for the future :)
CoolColJ
I always thought Bidirectional MLT was smart enough to know when things can't be seen they shouldn't be attempted to be calculated?
What about stuff behind the camera that can't be seen, but will still influence the lighting?
so does the same thing happen with Pathtracing/MLT as well?
Well MLT doesn't seem to render the scene very well anyway....
alex22
Post by alex22 » Thu Sep 13, 2007 10:25 am
I thought so too. I mean, I thought bi dir meant rays are sent from the camera too instead of just from the lights?
Post by OnoSendai » Fri Sep 14, 2007 12:12 pm
No, bidir mlt isn't 'smart enough' to magically avoid all sections of the scene behind the camera, esp. considering the indirect illumination from them may be significant for the final render.
CoolColJ
Post by CoolColJ » Fri Sep 14, 2007 5:47 pm
Kram1032 wrote:I love the top right one O.o
you should have made a bump map from the high poly model and used it for the low poly one - that should give close to similar results, then ;)
I just realiased... no bump maps on specular material :cry:
I have not had any luck creating an overhead shot of a pool where you see all those caustics under the water like you do in real life - is it an Indigo issue?
Users browsing this forum: No registered users and 95 guests
