CoolColJ's test pics thread
Post by Kram1032 » Mon Sep 10, 2007 5:28 am
looks very cool :D - a really alienish looking material!
Also your last cgsphere looks great! I prefer the right one ;)
CoolColJ
Post by CoolColJ » Mon Sep 10, 2007 5:30 am
fixed the water model issue, but it looks strange now.... I think I need more polys in my water. 16,000 polys currently
and Sketchup is already choking when I try to do anything with this water :?
CoolColJ
Post by CoolColJ » Mon Sep 10, 2007 5:32 am
Kram1032 wrote:looks very cool :D - a really alienish looking material!
thanks I will use the one on the right but with an extra row or 2 of orbiting things at the top :)
Post by Kram1032 » Mon Sep 10, 2007 5:34 am
lol, you even can make alien water caustics :P
yeah, that will come out pretty neat, I think :D
CoolColJ
Post by CoolColJ » Mon Sep 10, 2007 5:39 am
SSS version... I was hoping to see sunlight beams filtering through, but the water model is really odd....
anyway the MLT version of this doesn't even have any sunlight or shadows!
Post by Kram1032 » Mon Sep 10, 2007 6:05 am
sunbeams appear very late :? - they need very long... you'd need to render it longer, to tell, if there are some ;)
Moses
Post by Moses » Mon Sep 10, 2007 9:57 am
It may be a normal smoothing problem.
CoolColJ
Post by CoolColJ » Mon Sep 10, 2007 7:10 pm
yeah probably is...only way around that is up the poly counts...
changing the smoothing angles in Sketchup didn't help
I tried creating a high poly water model, 250,000+ polys, and it exported and rendered ok out of C4D with Cindigo, takes a while. Lush caustics! More like ocean water though, but rendered really slowly...
The bottom row of the pic is the poly reduced version at 55,000+ polys, which should look similar apart from the first render having a black absorbtion so it renders with more detail. Low poly version rendered 4 times faster! There are some flipped normals, I think, with the black areas, but the water model is quite angular, and arcs over on the crests.
The white parts on the surface, I don't know what they are, but they look like water foam. And the white artifacts adds to the look :)
They could be caustics refracting from the bottom as the water is totally clear.
I'll try and create a 32,000 poly water and export it out to Sketchup and see how it goes.
Post by OnoSendai » Mon Sep 10, 2007 7:46 pm
Wow, nice looking tests :)
Top right one looks sweet.
Stur
Post by Stur » Mon Sep 10, 2007 11:12 pm
Top left too :D
Post by suvakas » Tue Sep 11, 2007 1:49 am
Nice indeed !
Post by Kram1032 » Tue Sep 11, 2007 1:52 am
I love the top right one O.o
you should have made a bump map from the high poly model and used it for the low poly one - that should give close to similar results, then ;)
CoolColJ
Post by CoolColJ » Tue Sep 11, 2007 10:36 am
hey thanks guys - I'm surprised how well it turned out as well! :shock:
Definitely turning it into a proper scene later on 8)
well C4d reports it as 256,000+ polys, but sometimes it reads as 500,000+ triangles...when I export it out to the fry demo, that's what it says as well.
I'm really surprised how fast the Fry demo renders a similar scene!
Way faster than Indigo, I'll post the Fry result in my Fry demo thread later on...seems to be 3 times faster and Maxwell doesn't even render it properly.... But I prefer the finely detailed Indigo result though, just wish it had Fry's speed :)
Kram - I'm still trying to figure out how to create a bump map from the high poly object myself. Is there some program you can use to load both models into to create a difference bump map or something? Maybe I can do it Silo
Lord of the Rings Junkie
Post by Lord of the Rings Junkie » Tue Sep 11, 2007 10:58 am
CoolColJ wrote:Is there some program you can use to load both models into to create a difference bump map or something?
XNormal.
CoolColJ
Post by CoolColJ » Tue Sep 11, 2007 1:02 pm
thanks, will check it out
Users browsing this forum: No registered users and 123 guests
