Hello
i just bought 2nd pc and want to use it like render node for indigo , now i have full indigo, so i can use 2 render nodes
but i dont know what to do /in software way/ to make it work .
can u help me ?
render node
Re: render node
For starters, have you helped yourself to...?
Indigo Manual: Network Rendering
Re: render node
ok i did it like tutorial said but it write something about unlicensed frame resolution , and it abort network rendering ,
so i have a question how to setup slave to render with license ? i have one full indigo 4.x.x license and it says i have two render nodes with it .
Re: render node
Connected to render master.
Indigo Exception: Already failed loading this scene before, abandoning load. Previous error message: Aborting network render, image dimensions exceed unlicensed limit.
Connection to render master terminated.
Re: render node
so does this means i have 2 render nodes but running only in free mode ?
and i have to buy render node licence to render with full resolution ?
- juan_irender
Re: render node
Hi jan1.
Every render node has its own licence key. You must activate each node with its key, in the licensing menu, section licence key.
Ciao!
Ciao!
C4D R18 Studio user
Blender user
Blender user
Re: render node
ok i found way how to make it working ,
i just have to open indigo render on slave machine and put licence key there
then i have to run network slave and network manager and all is working now
ofc network rendering is quite slow in updating image , otherwise is good .
