[REQ] Tracing priority
Post by Kram1032 » Sun Sep 02, 2007 11:17 pm
hum... but indigo starts tracing a ray from the camera, as far as I know, so, if you say indigo "shoot a ray in that direction", the ray gets seen for (with bidir) close to 100% - it tries to find a lightsource and bounces around, before. that's the way, how it gets it's colour :)
jukka
Post by jukka » Tue Sep 04, 2007 3:05 am
I would like to suggest a new "weight" item for the material that would simply tell indigo how many samples per pass to calculate when it hits that specific material (I guess it would be meaningful for directly visible objects or specular reflection, not as much for diffuse reflection). I think that it would be pretty trivial to implement using only integer values for this parameter.
This method would help with reflections and refractions because you wouldn't have to define separate "regions of preference" for the reflection/refraction and object itself. It would also help if you have many objects using the same SSS material, for instance. Such a parameter could also be added to objects, so if you had an object that's very important you could boost its weight, and if that object used a material with a higher sampling weight, the total number of samples would be the product of those two weights. That would allow for pretty flexible tweaking of the tracing priorities IMHO.
Post by BbB » Tue Sep 04, 2007 3:49 am
I'm not sure I'm too hot on aeronoise. It seems like the typical "great" idea that turns out to be useless in practice. The samples I've seen show very clear "stamp" marks around the highlighted area, which I guess could be difficult to get rid of unless you let the image render forever, which kinds of, uh, defeat the purpose of the whole thing. Maybe priorities assigned to specific objects would be better...
Post by CTZn » Tue Sep 04, 2007 4:35 am
I'd prefer a solution where geometries (or materials, or possibly both) are marked as slower to converge before rendering, like precedence for sss
instead of a bounding box I suggested to name objects that should have a higher priority.
Why not just say: "object X should receive more rays"?
Concentrate your mind, ppl, save glucose ! ;)
Post by Kram1032 » Tue Sep 04, 2007 4:53 am
lol, yeah :D
besides that, there where two more suggestions (if I didn't miss any)
the "target portal mesh" (CoolColJ)
and the highly complicated "Forumlasolution" (me)
Post by BbB » Tue Sep 04, 2007 7:36 am
Experience shows that, if repeated often enough, aspirations become reality.
Post by CTZn » Tue Sep 04, 2007 8:25 am
:) thats right, but I felt the thread was becoming a bit confuse while the ideas where similar.
Yep kram you missed zsouthboy's suggestion, using a bitmap mask ;)
zsouthboy
Post by zsouthboy » Tue Sep 04, 2007 11:31 am
Note that my recommendation is simply Fryrender's solution (which marks the areas in the same way), except with an extra step, as I know how much Ono loves GUI programming.
psor
Post by psor » Tue Sep 04, 2007 10:28 pm
*tadaaaa*
Erm, ... sorry to bump in here, but AFAIK fryrenders Aeronoise is not a
solution for this problem. It is intended to get a better preview of diff.
areas in the scene, not to clean noise for a final image. :P :D ;)
... just my two cents. ;o))
take care
psor
"The sleeper must awaken"
zsouthboy
Post by zsouthboy » Tue Sep 04, 2007 11:50 pm
I disagree with your (and others') assessment.
It's perfectly useable.
If you're seeing "stamp marks" because of the different in noise levels, you're not allowing the rest of the non-aeronoise'd scene to converge long enough.
psor
Post by psor » Wed Sep 05, 2007 12:54 am
@zsouthboy
I know what you're talking about, but from my POV it would be not very good
for the workflow, to sit the whole time in front of the renderings till disabling
Aeronoise and let the image converge ... just my 2 cents. ;o))
take care
psor
oogsnoepje
Post by oogsnoepje » Wed Sep 05, 2007 2:26 am
Well, it would get you many nights full of joy. Wouldn't that be worth it? 8)
CTZn wrote:Concentrate your mind, ppl, save glucose ! ;)
I'm sorry, my mind was noisy at that time, should have let the reply clear up a bit longer :oops:
Post by CTZn » Wed Sep 05, 2007 3:29 am
Look mate, I am sorry you took my words that seriously ;) furthermore you wrote:
(probably the same as mentioned above but I didn't read the linked topic)
so you were not the less aware here. Now I feel confuse. Before i make a real reproach, muuuch more has to be done ! I've got a kind of humour that most ppl take seriously, I should watch this...
Cheers !
Post by Kram1032 » Wed Sep 05, 2007 3:39 am
:lol: - I guess, if we'd hear your voice, that wouldn't be a problem ;)
Forums are very critical for humor :?
but if you add a [joke] tag, it's loosing it's funniness :|
Post by CTZn » Wed Sep 05, 2007 4:06 am
Kram1032 wrote::lol: - I guess, if we'd hear your voice, that wouldn't be a problem ;)
Man, even in real life. People is more often flabbergasted than amused... because they are affraid i'd be serious :lol:
The fact is that I have no problem with self-derision... it's an institution for me, quite healthy ;)
