Looney Gears (MoI exercise)
Lord of the Rings Junkie
Only 400 x 400, but it's the best I could find with google. That's one of the reasons I wan't to scale the grain down a bit too. I just loaded it into GIMP and made it tileable to get it ready. Resolution is fine for the animation size render, though.
- W9000009_Windsor_Mahogany.jpg (24.61 KiB) Viewed 3415 times
Okay everybody, here is your first look at the animation! Only an Open GL render though. link
Hmm, will test. The main thing I'm worried about is render time, I want the anim to be 500 frames. The final still piece will have all the bells and whistles as far as rendering goes of course.
[Edit] Nope, BiDir is more than twice as slow.
[Edit2] New animation quality render, 200 spp just under 18 minutes.
- im1189108097.png (344.08 KiB) Viewed 3256 times
you should try and paint the scratches directly to the model to get a better effect if you can. It's more work, but better for realism
if you don't have glass and complex caustics MLT will be faster, and have a smoother look. Bidirectional MLT does add a lot of artifacts and grainey overall look until the image totally clears up
