CoolColJ's test pics thread
CoolColJ
Post by CoolColJ » Mon Aug 27, 2007 11:35 pm
I'm talking about the main camera itself, when you press num pad 0 to hook into it, and then grab it, you can't really control it the same way as you can in other 3D apps. I end up all over the place and tilted over when I rotate :(
anyway I did manage to get that scene into Blender after the 5th try, I don't know what went wrong, but I did fiddle with the OBJ import settings
see here - and I discovered a texture bug while I was at it :)
http://www.indigorenderer.com/joomla/fo ... php?t=2483
DaveC
Post by DaveC » Tue Aug 28, 2007 12:23 am
To rotate the camera, press R. Then you can constrain the rotation on whichever axis by pressing X, Y, or Z (vertical). If you press the key twice, it's rotated on the cameras local axis and not world axis.
These constraints work in translation (grab/move) too. press the key G,X,X and you will move the camera along it local X-axis.
If you press shift-X, Y or Z, you constrain to the other two axiseses. Press shift-Z and you can move the camera along the x and y axis-es. es.
Hope that helps.
CoolColJ
Post by CoolColJ » Tue Aug 28, 2007 7:31 pm
thanks for the tips guys, much appreciated. it helps a lot!
wonders if these should be factory defaults....
managed to setup blender to sorta act and look like C4D with a view outliner on the right :)
Post by Kram1032 » Wed Aug 29, 2007 4:08 am
not too hard to setup blenders window order :) - 2.5 release also will have better menus and programmable shortcuts, so that you can simply program similar shortcuts :D
CoolColJ
Post by CoolColJ » Sat Sep 01, 2007 7:55 pm
The original Milk SSS values work pretty well for statues and ceramics even if they don't do milk so well :P
Try that in Maxwell or Fry :wink:
Post by Kram1032 » Sat Sep 01, 2007 8:36 pm
that vase looks cool :D - you should blend it with phong or diffuse, though, to get some nice more solid looking results :D
(and did you ever manage to make that milk SSS clean? Would be good to see, how it looks in the end ;))
CoolColJ
Post by CoolColJ » Sat Sep 01, 2007 10:44 pm
I get funny results when mixing SSS and Diffuse/phong. Probably some bug in Indigo and bidirectional where you get these multi-coloured samples and bright spots that make the image go black....
Clean SSS....well it's just a matter of more CPU horsepower, rendering time and patience :twisted:
Bah I have so many final renders to do, the backlog is piling up! :?
Playing around in Sketchup and got some more ideas for renders, but will probbaly wait till I get my Quad core system to render up a big final clean render, as speed is so slow even at these small sizes :(
Glass, SSS, Reflective phong and bump map = melting CPU :evil:
at least the exit portal helps.... gotta say there probably aren't too many renderers that could do justice to this type of scene with accuracy as well. There is some serious level of light interaction here! 8)
only Bidirectional MLT allows this scene to be rendered properly
Post by Kram1032 » Sat Sep 01, 2007 11:40 pm
that test really looks great :D
I guess, the upper one is the correct one?
I like that caustic refraction in the upper right orange sphere :D
CoolColJ
Post by CoolColJ » Sat Sep 01, 2007 11:45 pm
bottom one is exactly the same as the top one, but with the white panels on the walls which really changes the mood, and water above the tiles.
The funny thing with the 2nd one is that you don't see the Sun, due to refraction, but you might later, as I find sometimes it takes a while for things to resolve. But it might be just the way it is, maybe that is the physically accurate result :)
Or an Indigo bug......?
We'll see I guess, I'm rendering a slightly larger version with better settings right now for longer.
I have another variation where the sun beam cuts through the middle of the purple slab, and you can really see the SSS in action then
Post by Kram1032 » Sat Sep 01, 2007 11:48 pm
cool :D
CoolColJ
Post by CoolColJ » Sun Sep 02, 2007 12:24 am
maybe I can add some SSS dust/fog to really kill the rendering speed.....
Post by Kram1032 » Sun Sep 02, 2007 2:04 am
xD
when you're at it: add cbc to all your transparent stuff :P
CoolColJ
Post by CoolColJ » Sun Sep 02, 2007 9:44 am
CBC?
Post by suvakas » Sun Sep 02, 2007 9:21 pm
cauchy_b_coeff ? (aka dispersion)
Post by Kram1032 » Sun Sep 02, 2007 10:19 pm
yep, thx for suv :)
Users browsing this forum: No registered users and 116 guests
