Fatal Error
5 posts • Page 1 of 1
dylancarey
Fatal Error
Post by dylancarey » Sat Sep 01, 2007 6:22 pm
This is not so much a bug but more like I think I screwed up in the process of moving from Skindigo 7 to Skindigo 9. This is the error I get whenever I send the SketchUp file to render. Any incite would be greatly appreciated.
Fatal Error Message
Dylan's Problem.JPG (81.3 KiB) Viewed 1375 times
Big Fan
Post by Big Fan » Sat Sep 01, 2007 6:39 pm
Along the way of development Indigos xml tags have changed for some materials.
'albedo_spectrum' is one of these changes.
I think most likely you have got something mixed up when you changed versions over.
You are either using the wrong exporter or the wrong indigo version together - or perhaps you have not changed the path
dylancarey
Post by dylancarey » Sat Sep 01, 2007 6:45 pm
What is the quickest easiest way to fix the problem.
Big Fan
Post by Big Fan » Sat Sep 01, 2007 6:48 pm
are you certain you have the right versions together and you removed the previous skindigo files including the path.txt before adding the new ones?
if you have skindigo 09 you need indigo 09
dylancarey
Post by dylancarey » Sat Sep 01, 2007 6:53 pm
That there is probably my problem. thanks... I will let you know if it still doesn't work. Hopefully it does. I have dial-up so its a pain to download things.
Users browsing this forum: Google [Bot] and 4 guests
