Cindigo 0.9 - beta 1
ok, i made a quick test.. it works fine.. i suggest you to put the model near the 0,0,0 coordinates. I don't see the reason why you should keep the glass on the windows, but i left it..
i always use a camera target, to have better control on the DOF.
I do mark the 'export settings to xml', to correct-change the settings of the .igs file quickly..
you can set the MNCR and the Max Depth low, for the tests, (check my file).
don't forget to insert the line <gamma>2.2</gamma>, after the material glass, otherwise Indigo gives you an error..
ciao!
Sorry, ZomB, we posted at the same time..
ciao!
- Alain.rar
- (82.87 KiB) Downloaded 239 times
- a 12 minutes rendering..
- im1188210209.jpg (185.9 KiB) Viewed 4325 times
update!
CINDIGO 0.9 - BETA 1
download exporter:
PC Version
(or below)
The file contains PC versions for R10 and R9. (R10 users will have to rename the "cindigo0.9.1.cdl_R10" to "cindigo0.9.1.cdl")
No Mac version to come, sry.
new in 0.9 - beta 1:
* no more object tag (normal smoothing is on if the object has a phong tag, if "visible in render" is of object doesnt get exported)
* new material tag (materials created with older versions might be incompatible)
fixed-list 0.9 - beta 1:
* gamma
known bugs/issues 0.9 - beta 1:
* only UVW-mapping supported
* nurbs should be made editable
* rotation bug still there
please post bugs
a good tutorial can be found here (only german and italian, hope someone will translate it to english soon).
extraextra: a little baking tutorial
download exporter:
PC Version
(or below)
* gamma
please post bugs
- cindigo0.9b1_3.zip
- Cindigo 0.9 - Beta 1
- (452.54 KiB) Downloaded 36683 times
Hey Fused... A great release with a lot of new Features!!!
Poorly atm I've got no time for a "deep scan", but I'm sure the isn't much left to fix anyway
But I just discovered, that "Absorption Spectrum Type" and "Scattering Spectrum Type" can be set also to Peak and Black Body?!?
Users browsing this forum: Google [Bot] and 11 guests
