Indigo 0.9.6 Vs FryRender 1.8 demo(up-date)
filippo
Post by filippo » Thu Aug 30, 2007 6:09 am
Hi, I do a litle test to compare Indigo and fryrender on 3d studio max.
all the parameters are equal.
filippo
sorry for my poor language
render time 32 minutes on 2 x Intel Xeon quad
indigo image
indigo 32 min.jpg (359.65 KiB) Viewed 21572 times
fryrender image(no exit portal)
fry demo 32.jpg (465.74 KiB) Viewed 21576 times
zsouthboy
Post by zsouthboy » Thu Aug 30, 2007 6:17 am
Exit portals? (In both cases?)
filippo
Post by filippo » Thu Aug 30, 2007 6:20 am
yes...exit portal in both cases!!!....in 30 minutes..I post the maxwell image...
Post by OnoSendai » Thu Aug 30, 2007 6:23 am
I'm not sure your Fry exit portal is working.. seems pretty slow.
Post by Kram1032 » Thu Aug 30, 2007 6:54 am
the light situation slightly changed...
vansan
Post by vansan » Thu Aug 30, 2007 7:17 am
No portals here, for sure!
tizxx
Post by tizxx » Thu Aug 30, 2007 7:35 am
Ciao Filippo
Gli exit portal in FRYRENDER non sono dei semplici piani...
come è invece possibile inserire in Indigo Render...
Devi creare un parallelepipedo delle dimensioni del foro e fori di apertura gli togli una faccia inverti le normali, o fai in modo che puntino all'interno della stanza...
le 5 faccie del parallelepipedo devono restare fuori dal foro ed essere attaccate al foro stesso...
leggiti sto tutorial...
http://www.fryrender.com/sh_images/tuts ... ortals.pdf
ciao ciao
:lol:
TiZxx
filippo
Post by filippo » Thu Aug 30, 2007 8:40 am
I am rifaring rendering in Fryreder with exit portal on.
and I test the maxwell in the same scene...
filippo
filippo
Post by filippo » Thu Aug 30, 2007 8:42 am
tizxx wrote:Ciao Filippo
ciao ciao
:lol:
TiZxx
sto gia rifacendo il test con fryrender con l'exit portal acceso....
am already RIFARING the TEST in fryrender whit the exit portal on...
Post by Kram1032 » Thu Aug 30, 2007 8:45 am
I think, your exit portal in indigo is too small! there is a pixel line, that rendered black ;)
filippo
Post by filippo » Thu Aug 30, 2007 8:47 am
Kram1032 wrote:the light situation slightly changed...
in the image of fryrender the exit portal it's off...sorry...
but the light situation it's the same......to set the direct light in Indigo as the sun in fryrender I have used my Indigo tutorial's(http://www.indigorenderer.com/joomla/fo ... php?t=1241)....but the result it is not the same...why?
when I finished the speed test I post all the scene....so you can se the sun parameters...
filippo
Post by Kram1032 » Thu Aug 30, 2007 8:59 am
the sun comes from exactly the same position?
then, it might be, 'cause of bidir ;)
filippo
Post by filippo » Thu Aug 30, 2007 9:12 am
maxwell test in the same scene .
render time 32 minutes(all the image are renderer in the same workstation)
filippo
maxwell 1.5 image
Post by Kram1032 » Thu Aug 30, 2007 9:16 am
interesting.... the sky looks much brighter, in maxwell...
indigo's the best, I'd say :)
fry is rendering with most contrast, as far as I can judge it :)
vansan
Post by vansan » Thu Aug 30, 2007 9:32 am
Maxwell 1.5 and Fry beta1.8 sacrificed the sharpness of the render to speed up noise clearing.
Indigo is the best! :)
Users browsing this forum: No registered users and 190 guests
