Glass material or a more detailed documentation ?
Post by Kram1032 » Sun Aug 26, 2007 3:22 am
in that case, you had an other material.... or an rgb emitter or something like that... (do rgb emitters have gamme values?)
Alain
One more question to the material glass
Post by Alain » Sun Aug 26, 2007 3:27 am
As you can see in the file "how_it_should_be.png" there is a balcony outside.
I just removed the glass geometry to let the sun in.
But if I add the glass geometry and add the glass material it looks like in picture "how_it_is.png"
whats wrong with the glass material ?
Post by Kram1032 » Sun Aug 26, 2007 3:59 am
your glass looks bended and as if it has slight colour... ;)
carbon
Post by carbon » Sun Aug 26, 2007 4:39 am
has your glass some volume or it is a single plane.. should be volume. also check if normals are pointing outside
Alain
Post by Alain » Sun Aug 26, 2007 5:05 am
the has glass has a volume and its not bendet ;-) normals are pointing outside on the left glass and inside on the other 2 glasses. If I turn the other 2 outside the glass gets just black.
what else could be wrong ?
Post by suvakas » Sun Aug 26, 2007 5:22 am
Do you have a bump map applied?
Too high ior ?
carbon
Post by carbon » Sun Aug 26, 2007 5:23 am
try to render only all glasses, maybe there is another unclosed medium somewhere in the scene, i remember that i experienced once something like this, i had to remove all objects one by one until i found the bad one
Post by Zom-B » Sun Aug 26, 2007 5:32 am
Alain wrote:I guess this is a bug in the cindigo exporter ?
It seems you missed my post dude >link<
zsouthboy
Post by zsouthboy » Sun Aug 26, 2007 7:49 am
Looks like you have normal smoothing turned on for the "glass", which causes that effect.
Post by Kram1032 » Sun Aug 26, 2007 7:51 am
hey, yeah, that could be it!
Turn of normal smoothing ;)
Alain
Post by Alain » Sun Aug 26, 2007 9:29 am
thank you guys, that was it ! :-)
cpfresh
Post by cpfresh » Tue Aug 28, 2007 11:26 am
looks like a cool scene, please share your final render! :D
Alain
Post by Alain » Wed Aug 29, 2007 8:20 am
I will, but I hope you can support me with your knowledge ;-)
se thise thread:
http://www.indigorenderer.com/joomla/fo ... 9586#29586
regards
alain
