Sketchup modeling tips.
try add detail in the sandbox. if you post a screenshot explaining exactly what you're trying to do it will help.
BTW, another tip: edit the faces in your style so the frontfaces are say yellow and backfaces are red or something and it will be alot easier to spot backfaces. i find the default purple backfaces hard to spot sometimes, specially when not directly in the light.
yeah that is a handy tip
anyway see these cubicles, they need more mesh resolution and the edges bevelled and smoothed but I can't figure out how to do it now in SU
probably easier to export it out to an external modeller like C4D or SILO and auto beveled plus sub-divide it...
man SU must be programmed in visual basic or something, gees does it slow down with anything remotely complex. Plus right clicking in SU can take forever sometimes. Some massive lag happening these days
And it's a memory hog too with models of mdoerate poly counts....
- CCJ_PhongTestingIGS_1232samples_im1187518666.JPG (98.1 KiB) Viewed 4424 times
At risk of stating something obvious, depending on at what stage your model is at, the number of segments in a curve can be changed. See attached.
If the curve is 'married' to some other geometry, then obviously cant change it. So yes, it does help to plan in advance!..
- segments.jpg (76.15 KiB) Viewed 4397 times
Users browsing this forum: DotBot [Bot] and 4 guests
