"They came at night" w.i.p
What version of Indigo gives you this problem? If 0.5, you'll need to run in "networking" mode with two slaves. If 0.6, you can do the same, or use the -t X command line option (where X is the number of threads).eman7613 wrote:...for some reason indego wont use both cores though:(
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
You can downloaf 0.6 from here: http://www.indigorenderer.com/montecarl ... _test1.zip
Sander "Roger" Wit
The Netherlands
The Netherlands
EDITED:
thanks, worked perfect, ior example in the test redners
laptop
.5 Mutations per second: 70349.350361
.6 Mutations per second: 123363.131205
desktop
.5 mutations_per_sec: 104198.949317
.6 (for some reason change on me) was at mutations_per_sec: 186301.184743 then switched to mutations_per_sec: 206064.345629
dont under stand why it would jump back and forth betwene the 2 every minute or so O.o
laptop
desktop
Yes i know, my spelling sucks
I'm still making test renders and modifying tiny little things (I've made a new clock, rearranged the cube-fella's, changed the light setting a tiny bit, tried to get the background to look nice, but when I change the background colour to pitch-black with a tiny bit of blue, the sky looks really blue, and it illuminates too much. So I changed it back to black to turn it off, and added a meshlight to simulate the moon, but it isn't working out the way it should. I want the background to be really dark with an inch of blue, and I want it to illuminate a tiny bit. 'Couse the rendering takes so long, the testing takes long. But I like where it's heading, personally, and I hope it'l turn out nice.
Arg, the sky is now totally back
. Poop. I'l see what I can do. Or perhaps you guys know of something.
In Blender Internal there is such a thing called "shadeless" than a surface with that material isn't illuminated, doesn't have specular or such of things, just the color (and/or the material) totally visible. Is there such a thing possible with Indigo? For I want to keep the background black to turn of the sky illumination, but I want the background to look really dark blue.... Ideas?
Sander "Roger" Wit
The Netherlands
The Netherlands
- Kosmokrator
Eman7613, if your offer still stands, I've packed all the textures and the .xml file in a WinRar file. I have uploaded it to my site. Here's the file. (2.9 MB WinRar package) It is exported from Blender for Indigo 0.5. I've tested it, and it works fine. But should I export it to 0.6 instead? I haven't used 0.6 before, but I can use the 0.6 exporter to export the scene to 0.6 if it is needed.
Anyway, the file is uploaded to the url above. I would really really appreciate it if you'd render it for me (the render resolution in the xml file is 1000x500 but you can change it if nessecary).
If it needs to be a 0.6 file, please let me know.
Cheers
Sander
Cheers
Sander
Sander "Roger" Wit
The Netherlands
The Netherlands
