[REQ] Aggiunte a Maxigo....(Additions to maxigo...).
4 posts • Page 1 of 1
Giojazz
Post by Giojazz » Wed Aug 15, 2007 3:12 pm
Vorrei chiedere al gentile programmatore "Suvakas" se è
possibile inserire nella prossima versione di Maxigo le
seguenti aggiunte:
- ENVIRONMENT -
"sky gain"
- CAMERA PARAMETER -
"f-stop"/aperture 0 - 64
- TONE MAPPING -
"linear"
- ADVANCE SETUP -
"overall gamma correction"
Grazie.
I would ask the Gentile Programmer "suvakas" is it possible to insert in the next version of maxigo the following additions:-Environment-" Sky gain "- Room parameter-" F-stop"/openings 0-64-tone mapping-" linear "- advance Setup-" overall range correction" Thank you.
Post by suvakas » Wed Aug 15, 2007 8:17 pm
Thanks for using Maxigo Giojazz 8)
Linear mapping is already there. ISO = Linear tone mapping
Why do you need such a large f-stop range?
Post by Kram1032 » Thu Aug 16, 2007 12:22 am
1 - 64 would be more reasonable, as 0'd be an infinite aperture...
sky gain isn't needed, anyway - it does nothing ;)
overall range correction?
what does that do?
Or what it's *supposed* to do?
Kinda an auto tonemapping? - that would be a nice feature (for any exporter) indeed :)
Giojazz
Post by Giojazz » Thu Aug 16, 2007 8:19 am
Chiedevo al gentile programmatore "Suvakas" di inserire questi parametri in Maxigo perchè presenti in modo nativo in INDIGO RENDER e implementati normalmente in Blendigo perchè io personalmente li ritengo utili...potrebbero farmi comodo in molti lavori.
Credo potrebbero fare comodi a tutti, per quando riguarda
il "F-stop/aperture" volevo intendere da 2 - 64 così da poter
controllare in modo più efficiente la luminosità e la messa a fuoco.
grazie.
I wanted Gentile Programmer "suvakas" to insert these parameters in maxigo why has the native Indigo render normally and implemented in blendigo because I personally I think useful... could make me comfortable in many works. I believe could be comfortable at all, as regards the "f-stop/aperture" I wanted understood from 2-64 to check more efficiently the brightness and the focus.
Thank you.
Users browsing this forum: Bing [Bot] and 48 guests
