Indigo MultilightTest
Sebastian
Post by Sebastian » Wed Aug 15, 2007 1:48 am
Here's a little test i did with rendering the Light-passes in different "Frames".
For that I used the Blendigo Export-Script and the Export animation Feature for automatic rendering.
Multilight is a intresting Feature for Lightsetupping, because if you've rendert your Lightpasses, it's very handy to configure the Lights if you want to and you haven't to render everytime a new test to see if the Lightconfiguration is okay !
tizxx
Post by tizxx » Wed Aug 15, 2007 2:14 am
Can you explain to all more details...
my first question is how many time to render all aminamtion?
Is the same time for make one frame?
walter
Post by walter » Wed Aug 15, 2007 2:19 am
Well done! This looks pretty useful... I guess the only drawback is the extra time waiting for the separate renders.
One question: How did you combine the separate images? Was it some sort of "screen" or "add" or what ..?
Sebastian
Post by Sebastian » Wed Aug 15, 2007 2:25 am
You can combine the images with "Sceen", I used Gimp for that.
A good explenation of the method could seen here:
Indigo and Multilights
Post by OnoSendai » Wed Aug 15, 2007 2:29 am
Cute.. but physically incorrect, as I've written about before.
Post by Kram1032 » Wed Aug 15, 2007 2:37 am
Any way to make it correct, then?
walter
Post by walter » Wed Aug 15, 2007 3:03 am
Ono,
Could you explain again (or link to your previous explanation) of why this is physically incorrect? I've been looking through the forums, trying to find this but couldn't :(
I thought, that, as light properties are additive, and light waves don't interfere (at least, not on the scale we're talking about), doing a simple "add" function would be physically correct. Is the problem mainly re: tonemapping before/after the add?
Post by OnoSendai » Wed Aug 15, 2007 3:08 am
walter wrote:Ono,
Yup.
The correct approach is to form a linear combination of the *un tone-mapped* image buffers, *then* apply the non-linear tonemapping operation.
Applying the non-linear tonemapping operation first (i.e. mixing the PNGs) is incorrect.
walter
Post by walter » Wed Aug 15, 2007 3:13 am
But, Indigo can save un-tonemapped images .. so, that's not too hard at all ..!
Post by OnoSendai » Wed Aug 15, 2007 3:15 am
walter wrote:But, Indigo can save un-tonemapped images .. so, that's not too hard at all ..!
Sure... if your image editor can mix EXRs :)
walter
Post by walter » Wed Aug 15, 2007 3:22 am
Right :D
I might be wrong, because I've never used it before, but it looks like Cinepaint can do this...
[edit] This might also be nice functionality to have in violet.
Post by OnoSendai » Wed Aug 15, 2007 3:33 am
Yup, would be awesome to have in Violet.
Unfortunately, the required GUI code is non-trivial :)
Post by Kram1032 » Wed Aug 15, 2007 3:44 am
Hmmm....
So, a good coder needs to do that :)
exporting exrs also would make the custom HDRis better :D
low prior request, that already was made, I think:
A panorama camera :D (360°, cylindrical or better spherical)
Sebastian
Post by Sebastian » Wed Aug 15, 2007 5:06 am
Unfortunately, the required GUI code is non-trivial Smile
Yes !!
that would be awesome. Hope one Day Violett support that feature, then we'll catch Maxwell with his "magic" :lol: Multilight function.
Here is a Gimp file with several lightsetups to try the IndigoMultilight-Mixing feature.
Water.rar
(2.03 MiB) Downloaded 239 times
zuegs
Post by zuegs » Wed Aug 15, 2007 5:12 am
this was my topic :!: :lol: :lol:
some long time ago (November 06), read/see it here:
http://www.indigorenderer.com/joomla/fo ... .php?t=739
regards zuegs
