Look again this Image...
Ono, It is possible to hide the geometry of EXIT PORTAL to the camera?
In general is possible to have the option to mask objects to camera ?
thank you for the attention
.:: Indigo 0.9T5 and Exit Portal -- third part
- exit-portal2.max-frame-0003.JPG (83.45 KiB) Viewed 8296 times
SimonLarsen
I suppose that if i can hide the exit-portal geometry to the camera i can't see the black area...
I see black rectangle because the geometry (in this case a single plane) has inverted normals...
then i know we must have 2 exit portal or one foreach aperture...
I'll see what respond Nicholas at my questions...
exitportals work the other way round...
this image has an exitportal, that brings all the light IN that room, but none, OUT of it...
They simply make light, going through THEM, ONLY, and that, in ONE direction (the direction of the normals) - so, this simply CAN'T work, this way (at the moment. There is an improvement possibility, as Ono already said...)
