Indigo 0.9 test 6
manuel
Post by manuel » Mon Aug 13, 2007 5:06 am
doesnt work with wine in my arch linux :-(
fixme:actctx:FindActCtxSectionStringW 00000000 (null) 2 L"msvcr80.dll" 0x337b6c
err:module:LdrInitializeThunk "MSVCR80.dll" failed to initialize, aborting
Macrob
Post by Macrob » Mon Aug 13, 2007 5:44 am
The same here with gentoo linux. test5 works :roll:
alenofx
Post by alenofx » Mon Aug 13, 2007 6:47 am
Wine solution (tested on OSX with a clean wine 0.9.43 installation from sources):
- "Microsoft Visual C++ 2005 SP1 Redistributable Package" NOT needed;
- Create in the indigo directory a new text file named "Microsoft.Windows.Common-Controls.manifest" with this content:
<?xml version="1.0" encoding="UTF-8" ?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
    <assemblyIdentity type="win32" name="Microsoft.Windows.Common-Controls"
version="6.0.0.0" processorArchitecture="x86" />
    <file name="comctl32.dll" />
</assembly>
EDIT: this solution works on linux too.
Wedge
Post by Wedge » Mon Aug 13, 2007 6:53 am
Hi Ono, is num threads deprecated with this version onwards?
Now, does this auto threads feature pick max threads available or?
Thanks! :)
Post by OnoSendai » Mon Aug 13, 2007 6:58 am
num_threads is still there.
if auto choose num threads is on, it sets the number of threads to the number of logical processors (i.e. number of cores).
joegiampaoli
Post by joegiampaoli » Mon Aug 13, 2007 9:12 am
I get this under wine with Ubuntu Linux :(
Then I get this status after fitting the ok button on that error window.
err:module:LdrInitializeThunk Main exe initialization for L"Z:\\home\\joe\\Desktop\\indigo\\indigo.exe" failed, status c0000142
Joe Giampaoli
My Indigo Gallery
alenofx
Post by alenofx » Mon Aug 13, 2007 9:18 am
@joegiampaoli: look at my solution, it's for this problem. ;)
blendergat
Post by blendergat » Mon Aug 13, 2007 10:49 am
gato wrote:It works in vista 64!!
Display took 3.97306 s
Time elapsed: 2 m, 34 s
Done 4740000.00000 samples (9.87500 samples per pixel)
30662.40942 samples / second (32.61322 micro-seconds / sample)
How fast it this results of my computer??
It´s fast (more or less) or is slow??
Thanks!!
P.D. My processor is a AMD 3200+ 64 bits, simply...
It is exactly 2X times faster then my 32bit computer.
Big Fan
Post by Big Fan » Mon Aug 13, 2007 12:29 pm
I really dont see the point of this auto thread.
Sorry ono I dont think i'll use it in my variant :roll:
Phr0stByte
Maybe for you...
Post by Phr0stByte » Mon Aug 13, 2007 1:16 pm
alenofx
This solution may have worked for you, but it does not work here on my Ubuntu (Gutsy) box. Test4 still runs nicely though. 5 and 6 are borked. Has anyone found a real fix?
manuel
Post by manuel » Mon Aug 13, 2007 1:22 pm
@PhostByte yes just copy the Microsoft.Windows.Common-Controls.manifest file from the test4 (or test5) dir into the test6 dir. this works on my linux box
Phr0stByte
Still no go....
Post by Phr0stByte » Mon Aug 13, 2007 1:27 pm
manuel
That did not solve the issue either. Getting the same error as everyone else...
my wine version: wine-0.9.25
Ubuntu (Gutsy)
AMD64 kernel
alenofx
Re: Still no go....
Post by alenofx » Mon Aug 13, 2007 1:47 pm
Phr0stByte wrote:manuel
Ubuntu (Gutsy)
AMD64 kernel
I've tested this solution on OSX and Ubuntu 7.04 64bit, both with Wine 0.9.43; your Wine version is a bit outdated, add the WineHQ APT Repository and update it: http://www.winehq.org/site/download-deb
GNUdo
Post by GNUdo » Mon Aug 13, 2007 7:59 pm
joegiampaoli wrote:I get this under wine with Ubuntu Linux :(
I noticed that in indigo_v09_test6.zip there is a folder named Microsoft.VC80.CRT containing some files that in previous 09 releases were in the main indigo folder.
Moving those files up one level solved the problem for me under wine with Gentoo Linux.
joegiampaoli
Post by joegiampaoli » Mon Aug 13, 2007 8:01 pm
I did what alenofx told me to try, works well, I will also test what you recommend and post edited result.
Thx
EDIT: Nope, I get exactly same error as above. So for me in ubuntu linux what alenofx recommends works perfectly well without a single error in console.
Joe Giampaoli
My Indigo Gallery
Users browsing this forum: No registered users and 67 guests
