Indigo 0.9 test 5 (x86 and x64 builds)
32 bit (x86) distribution:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
64 bit (x64) distribution:
changelog:
0.9 test 5
* faster tracing through scenes with many objects
* added Windows x64 build.
* OpenEXR env maps / output disabled in x64 build
Let me know if it works.
changelog:
0.9 test 5
- joegiampaoli
Thx Ono!!!!
Will be testing soon......
EDIT: (Can't wait for that linux version)
- Kosmokrator
Downloaded 9t5. Unzipped it and double clicked indigo.exe. See the picture for the result.
Previous versions required no specific installing. Does this one?
André
By the way: I have a Win XP 32 bit system running on a AMD X2 3800 dual core CPU and 2Gb memory.
André
Great ! Thanks !
Ps.
to Ono:
One minor notice I made.
I recently did a clean Win install and test4 didn't work "out of the box". It started to work after installing Violet. All the previous versions worked without the Violet. So test4 needed to have some C++ libraries or whatever files to be installed. If test5 is similar to 4, then i think it requires the same stuff.
Just thought I'll let you know.
Ps.
to Ono:
- drBouvierLeduc
Both versions return the same message as vulture with windows xp 64 sp1... sigh
edit: after installing sp2, the 32 bits version works fine... 64 still not
Last edited by drBouvierLeduc on Sat Aug 11, 2007 9:46 am, edited 1 time in total.
- Kosmokrator
Maybe Microsoft Visual C++ 2005 Redistributable Package (x86) is needed... give it a try Camox.
Users browsing this forum: Baidu [Spider] and 37 guests
