[bug] strange dark render + indigo connects to internet
I tried to make a testscene for my inverted sss post. The scene rendered ok. I tweaked the scene a little bit. Then my firewall (ZoneAlarm) warned me that indigo wanted to connect to the internet. I denied the request.
After that the render looked very strange. And it happened every time I tried to render again...
BTW: the scene cooked for 15 minutes in 2 threads on a AMD 4200+
- strange render
- im1186586939.jpg (57.67 KiB) Viewed 3168 times
- default.igs
- scene
- (108.84 KiB) Downloaded 175 times
- deltaepsylon
attaching the materials didn't seem to work (you canÄt attach .xml, can you?)
so here is the zipped scene with materials
- dark_scene.zip
- scene with materials
- (15.79 KiB) Downloaded 186 times
- deltaepsylon
- deltaepsylon
- deltaepsylon
Putting more focus to the sss issue:
The bug seems to be realted to high sss values. When I reduced the sss value it seemed to work ok.
Also using uniform instead of rgb for sss made everything look more ok (experience from earlier scenes with 0.9t4 not tested with this particular scene, though).
Maybe someone can confirm this for my scene (available in my second post in this thread)? Also could somebody try the effects of bidir on the bug? I don't have indigo installed where I am currently...
- deltaepsylon
- deltaepsylon
