SolidWorks Exporter
Announcements, information, requests and support regarding other exporters and general/new exporters
xrok1
Post by xrok1 » Thu Aug 02, 2007 7:55 pm
jeffr,
can you check this out for me? i'm trying to create a macro so that i can select a face, traverse the feature tree, and the macro will select all the other faces with the same color. (like a select by color option) but i just can't seem to crack it. the msgbox is just for testing purposes and so is the code that will only change the face to blue if the selection is white.
i hope you can understand my explaination. the biggest problem right now is how to make it automatically select the next face. i will worry about comparing the color to the next face later but i need to know how to select it first.
ignore the wishy washy code it a series of desperate attempts. any advise or snippits would be appreciated.
colorselecttest.zip
(12.1 KiB) Downloaded 626 times
xrok1
Post by xrok1 » Thu Aug 09, 2007 1:28 pm
come on back jeffr i'd love to see what you have.
jeffr
Post by jeffr » Thu Aug 09, 2007 2:58 pm
I'll post an update tomorrow but you can mess around with this update until then.
xrok1
Post by xrok1 » Thu Aug 09, 2007 3:42 pm
thanks i'll check it out :)
xrok1
Post by xrok1 » Thu Aug 09, 2007 4:43 pm
:lol: great!
i don't get why you think you have normal problems. i can see everything in my scene when i render? looks good.
by the way have you considered using the textures instead of the physical materials? or are you, because i thought i saw in one of your posts that you use materials not textures?
p.s surfaces still don't show up have you noticed this? there is a floor in this model but its a surface.
:D
jeffr
Post by jeffr » Fri Aug 10, 2007 12:11 am
8) I'm implementing the textures actually. I removed the parts that read the selected material and now just look for settings in the components for colour, specularity, transparency etc. and you can select a texture.
I am limited a bit with the controls provided within SW. I want to be able to use a texture but also use bump maps. Any ideas how to use both?
xrok1
Post by xrok1 » Fri Aug 10, 2007 4:23 am
i believe the only way you can do that is through photoworks which is accessible through the api. but then you're back into, might as well render through photoworks, which is a real pain but does give half descent results (i'll post some when i get home)
option 2. make an interface like skindigo where you can use blend materials aka layers to add add channels to the texture.
option 3. probably best bet and easiest to implement would be different configurations or display states might even be better, with specific naming convention such as bump, clip...
jeffr
Post by jeffr » Fri Aug 10, 2007 7:30 am
No if you right click on a part you can go to appearance and you can change colours, transparency, specular, shininess etc. You can also select textures. This can all be brought in and used.
Big Fan
Post by Big Fan » Fri Aug 10, 2007 10:28 am
I think SW08 realview uses bump maps so you should be able to find API stuff for it and also use env maps..
Really I think you should try to utilise 08 as a starting point for an exporter - perhaps you are a beta tester and can get access to the new API?
the normals might work better too... :roll:
xrok1
Post by xrok1 » Fri Aug 10, 2007 11:32 am
SW06 also uses all these features bump, env, masks...
xrok1
Post by xrok1 » Fri Aug 10, 2007 11:47 am
here is a photoworks render, not bad but a pain. SW06
Big Fan
Post by Big Fan » Fri Aug 10, 2007 12:19 pm
LOL
I leave you to it.. 8)
jeffr
Post by jeffr » Fri Aug 10, 2007 2:09 pm
SW 06 itself doesn't have bumpmap, environment map etc. but maybe photoworks does. Without having the photoworks add on I don't see a way to do it.
xrok1
Post by xrok1 » Fri Aug 10, 2007 3:04 pm
ok sorry, i have photoworks so i guess i assumed.
...but what about the display states idea?
P.S did i mention i love your interface simple and to the point. :)
jeffr
Post by jeffr » Fri Aug 10, 2007 3:33 pm
xrok1 wrote:ok sorry, i have photoworks so i guess i assumed.
Expand on what your thinking about display states. I think your saying make use of the ability to give a part a different configuration and try to pull up additional parameters from another config.
Thanks for your P.S. - has been my intent from the start :D
