SkIndigo Progress Updates (Whaat's Development Blog)
Mate I'm back on deck and really happy to see you have seemingly broken the back of what we could ever foresee being achieved through ruby scripting. Amazing!Whaat wrote:It is saved internally in the Sketchup scene file. It does not have to be visible or even be 'in use'. If you have used Sketchup, you would understand.Kram1032 wrote: Where is the real geometry???
I can't see it in the sketchup view.
I have a question on this subject! Is the instancing / component management handled by Layers or component names?
Actually I think I might have worked it out anyway like this would it work.
1. The component named say TREE COMPONENT contains two nested components TREE (on layer TREE) and TREE_DUMMY (on layer TREE_DUMMY),
2. The TREE COMPONENT is inserted in scene the TREE layer turned off (TREE_DUMMY on) and the scene populated and then exported
3. The nested component TREE_DUMMY is replaced on export with the nested component TREE!
Is this the work flow you considered or not?
Great stuff mate!
@Richard:
Hey Richard! It's been awhile! I think the workflow you mentioned should work. As long as the TREE_DUMMY component is on a visible layer when you export, it should be replaced with the tree component at export time. I have never tested this with both the dummy and the original component nested inside another component. Try it and see if it works! I suggest going through the brand spanking new SkIndigo tutorials (posted in the Tutorials Forum) That should explain the workflow that I had in mind when I created this feature.
- kwistenbiebel
a little taste of what I've been up to lately...
http://www.indigorenderer.com/joomla/fo ... php?t=2686
Simple UI Slider Calibration
The next beta of SkIndigo is almost here. With it comes a simplistic and intuitive (but still very versatile) UI mode. A challenge was tranforming the non-linear Indigo properties for IOR and exponent into a clamped linear range. The attached image shows how the sliders will be initially calibrated (I might tweak it some more in future releases...)
One of the coolest features of the new UI is that you can switch modes and any time and still retain the all of the material properties. For example, you could create a comlicated SSS material using RGB Scattering coefficients and HG phase function. Then, just switch to simple UI mode to tweak the reflection and roughness sliders. All of the SSS attributes will still be saved and exported when you render.
- Slider Calibration Reference
- Untitled.jpg (547.7 KiB) Viewed 12160 times
Roughness controls the exponent. It is independent of the bump map settings.crc wrote: how is the roughness factored if there isn't a bump map, or to put it differently, is that in the current exporter under a different name?
If the emitter checkbox is checked, the power slider controls the power of the lights.and what about that power slider, lights?
Cool, a co-worker wanted to do some renderings and it took maybe 10 minutes to show him how to set up materials, etc with Skindigo and he did a render overnight. He had never done any renderings before, a definite testament to how easy you have made this great exporter to use (and how good Indigo is). It looks like it will only get better!
Thank you!
Thank you!
It's a total hack. I just kept experimenting until I found an equation that I was happy with. I used MS Excel to do some curve fitting which helped quite a bit. I found it useful to convert the IOR back to a Specular value first. This equation is not a hack. You can find it on the Wikipedia and on the forums here somewhere.suvakas wrote:Looks cool !
Any tips how you convert the Roughness and Reflection values from 0 to 100 ?
Here is the current code (probably not the final code)
def to_reflection(ior)
ior=ior.to_f
specular=((ior-1)/(ior+1))**2
if specular<=0.0
reflection=0
else
reflection=Math.log(1000*specular)/0.0692
reflection=100 if reflection>100
end
return reflection.to_s
end
def to_roughness(exp)
exp=exp.to_f
rough=Math.log(exp/1000000)/(-0.14)
rough=100 if rough>100
rough=0 if rough<0
return rough.to_s
end
