Indigo 0.9 test 4
Textured Emitter Error
I'm trying to get a textured emitter working, but I am getting a message that says "error loading texture file". I am using a jpg file. Is this a bug? I have a cube, uv mapped, and textured with a picture. I have set the image location and emitter settings in blendigo (v. 9.0 t3). I am using indigo 9.0 t4
thanks
thanks
Onos Test Builds are quite stable and got some nice speed improvements,Lord of the Rings Junkie wrote:I just leave it to everyone else to test the buggy releases...
finding Bugs is getting quite hard these days
Indigo is quite sensible about image formats, get sure that your jpg file is saved in baseline Mode, and also at least 24bit...sciman wrote:I'm trying to get a textured emitter working, but I am getting a message that says "error loading texture file". I am using a jpg file. Is this a bug?
You can try to convert it to a bmp or png, but for both also stay basic, no fancy advanced saving options
I figured out myself right last night why some obj files could not work, thanks for caringOno wrote:* added support for missing texture coordinate index in .obj files
Workaround was to apply a dummy textCoord, found that 24h after 9t4 releaseobj files without texture coordinates didn't work.
- deltaepsylon
- deltaepsylon
Color error?
Hi all,
Just downloaded Indigo some days ago. I like it very much so far. I have also downloaded and installed BlenderIndigo and found the preview of a material strange. I ask for yellow glass and get green glass. The same happens when rendering my model. See picture.
Is it the difference in version number (0.93s <-> 0.9t4)?
If not, how do I get yellow glass?
Thanx a lot,
Andre
Thanx a lot,
Andre
- deltaepsylon
This issue seems to be discussed here!?
Way more informative then a smiley
+1 means I second the opinion of the previous posting.deltaepsylon wrote:@zomB: posting with +1 isnt all that helpful either...
try to decrease green, slightly - this happens also to blue: pure blue stuff comes out violetish - there, you'd need to add slight green
that was an SSS bug, this is a absorbtion bug... AND there, it was a inverted bug, here, the colour isn't inverted, but not actually correct colouredZomB wrote:This issue seems to be discussed here!?
what about "+1ZomB wrote:+1 means I second the opinion of the previous posting.deltaepsylon wrote:@zomB: posting with +1 isnt all that helpful either...
