Indigo 0.9 test 4 experimental 64-bit build
Argh! - I got all excited but it doesn't want to run for me - are there some new dependencies that I mightn't have installed?
I'm running Windows XP Professional x64 edition with SP2. No problems with the 32 bit builds, but when I start this build I get:
"The System cannot execute the specified program."
In the System event log I get the following:
SideBySide: Component identity found in manifest does not match the identity of the component reqested
SideBySide: Synax error in manifest or policy file "C:\indigo_09_test4.5_x64\Microsoft.VC80.CRT.MANIFEST" on line 4.
SideBySide: Generate Activation Context failed for c:\indigo_09_test4.5_x64\indigo_console.exe. Reference error message:The manifest file contains one or more syntax errors.
I also tried on a one of the XP x64 work machines, and got the same response.
- deltaepsylon
I've tested the build on my x64 workstation (WinXPx64SP2) and ran intoianammo wrote:Argh! - I got all excited but it doesn't want to run for me - are there some new dependencies that I mightn't have installed?
the same problems ... :/
take care
psor
"The sleeper must awaken"
- deltaepsylon
edit: link and text removed cuz zsouthboy thinks it might insult ono
I don't know how to phrase this:deltaepsylon wrote:ono should start looking even more into optimization. i was surfin the net ysterday and found this, might be of interest: http://www-d0.fnal.gov/KAI/doc/UserGuide/chapter_3.html
1) Premature optimization is the root of all evil. Period.
2) The link you posted, and the way that you posted it, implies to me that you are not a programmer, or have not been one for long.
Ono is hardly new to C++ - it's almost insulting to post that link. He knows what he's doing in regards to (incredibly simple programming concepts) that. Take a look at the code that he has released for other projects for proof.
- deltaepsylon
Users browsing this forum: No registered users and 81 guests
