A small animation test =)
Post by suvakas » Wed Aug 08, 2007 2:11 am
luqui82 wrote:Can you post the model on .3ds or .skp format? I want to try to render it with Skindigo.
Thanks in advance
Can Sketchup import obj format?
I think it doesn't fit into 3ds. It was over 70k polys, if i remember correctly. Will check when i get home.
luqui82
Post by luqui82 » Wed Aug 08, 2007 2:18 am
yes, there´s a plugin that can import obj files into sketchup.
thank you
crc
Post by crc » Wed Aug 08, 2007 5:00 am
suvakas wrote:I use 3ds Max.
No multiple scenes output or something like that. Animation is build into Max exporter. It exports a new frame as soon as the previous frame gets done. Everything is automatic and igs scene requires the same amount of disk space as for still image rendering.
Finally I used VirtualDub to render the png files into *.avi
So all you need for doing animations in Max is a fast cpu - which i don't have 8)
Post by suvakas » Wed Aug 08, 2007 7:36 am
@luqui82
Here is the model for you in obj format.
There are some f***ed up vertexes though. I have no idea from where those came from. But maybe you can still use it.
greeble.zip
(2.75 MiB) Downloaded 176 times
Post by suvakas » Wed Aug 08, 2007 7:40 am
Kram1032 wrote: Did you also use exit portals?
Sry, missed your question before.
Yeah, there is an exit portal on the window opening. Scene is lit by blue background color.
Post by Kram1032 » Wed Aug 08, 2007 10:09 am
ah I see :)
funny - doesn't look that blue^^
CoolColJ
Post by CoolColJ » Wed Aug 08, 2007 10:58 am
I'll play around with the model myself as well :)
SmartDen
Post by SmartDen » Mon Aug 13, 2007 7:50 pm
suvakas wrote: Finally I used VirtualDub to render the png files into *.avi
Can you please explain how did you rendered png sequence to avi with VirtualDub.
Post by suvakas » Mon Aug 13, 2007 9:21 pm
I used VirtualDub Mod v 1.5.10 (standard veresion doesn't support png i think)
You can get it from here: http://virtualdubmod.sourceforge.net/
png filenames must contain framenumbers. They should be in correct sequence. Then you just open the first frame (in my case greeble_frame_0000.png) and all the other frames are loaded automatically. After that it's just a mather of picking the codec and saving as avi. You can also change the frame rate under video/frame rate... I used 25 cause mine was done using PAL format in Max
SmartDen
Post by SmartDen » Tue Aug 14, 2007 1:24 am
Thanks a lot, suvakas!
BTW new version of VirtualDub 1.6.19 also supports png and works very fine!
Post by suvakas » Tue Aug 14, 2007 1:35 am
SmartDen wrote:Thanks a lot, suvakas!
Really? Cool. I havn't checked if there is a new version for a very long time.
Lord of the Rings Junkie
Post by Lord of the Rings Junkie » Wed Aug 15, 2007 4:41 pm
Nice! Very consistent noise level, thanks for the halt samples, Ono!
sciman
Post by sciman » Wed Sep 12, 2007 1:37 pm
What did you use to open each igs file, render it, and then move on to the next??
Post by Whaat » Fri Sep 14, 2007 3:28 am
sciman wrote:What did you use to open each igs file, render it, and then move on to the next??
BUMP for this question. C'mon suvakas...do tell.
Post by suvakas » Fri Sep 14, 2007 3:39 am
There are no multiple igs files. Only one.
I'm checking from maxscript if Indigo is running and if it is not, then I'm exporting a new frame + I add a frame number to output image name. That's it.
