CoolColJ
by CoolColJ » Tue Jun 26, 2007 10:49 am
anyone have any material settings for pool water for nice caustics etc?
by Kram1032 » Tue Jun 26, 2007 8:03 pm
simple water?
the colour basically comes from the pool-walls...
Phoenix
by Phoenix » Tue Jun 26, 2007 10:26 pm
Kram1032 wrote:simple water?
Sorry, but that's not totally true.
Even with completely white pool walls, the water will be appear bluish!
Unless it's a very shallow pool.
And that also happens without a blue sky above!
That's because the light absorption capacity of water which effects the shorter wavelengths less than the longer ones. So it becomes blue with increasing "thickness".
by Kram1032 » Tue Jun 26, 2007 10:54 pm
hmm...
no idea, how chlorine changes the appearance of water...
anyway, if your pool-walls are blue, as usual, it should look correct, I guess...
matsta
by matsta » Sat Aug 04, 2007 9:10 pm
hey guys
this thread has been dorment for a while now, thought id just spike it up again with a request, does anyone have any settings for porcelain. making a porcelain tea set.
thanks
mat
drBouvierLeduc
by drBouvierLeduc » Sun Aug 05, 2007 3:14 am
something like this maybe ?
phong material
exponent 60000
ior 1.8
- phong material
exponent 60000
ior 1.8 - porcelain.jpg (43.16 KiB) Viewed 4974 times
matsta
by matsta » Sun Aug 05, 2007 3:32 am
hmm very nice... its weird i think the look im going for is more along the lines of bone china but that mat is very nice. thanks alot drBouvier.
greetz
CoolColJ
by CoolColJ » Sun Aug 05, 2007 2:47 pm
exponent 60000...? Here I was thinking 10000 was the limit ... !
matsta
by matsta » Sun Aug 05, 2007 6:59 pm
lol coolcoj, i often using up to 1 000 000
greetz
by Kram1032 » Tue Aug 07, 2007 8:36 am
Exponent is limited to the maximum possible value in float or double float (dunno, which one)...
100000 is Blendgos limit.
I actually'd like a wider spectrum
matsta
by matsta » Tue Aug 07, 2007 5:32 pm
kram! u lie :O u sure that 1000000 isnt the limit... im sure i remember being told that 1000000 = mirror... o well
dont spose it makes a difference
greetz
mat
by Kram1032 » Tue Aug 07, 2007 9:49 pm
It doesn't really make a big difference, any more, yes.
But if you want "infinite" Exponent, simply use Specular instead of Phong
It *should* make a difference, though: If you have an infinite reflection, somewhere, and DAMN high RayBounceDepth...
If you're able to make out the LAST reflection, there may be a difference
Kram1032 on Fri Sep 14, 2007 6:48 am, edited 1 time in total.
deltaepsylon
by deltaepsylon » Thu Aug 09, 2007 3:32 am
one mil is the mirror thing, so 1 mil shud be the limit
by Kram1032 » Thu Aug 09, 2007 4:21 am
even "1" is a mirror, but it's SUCH blurred, that you can't see ANYTHING
(It looks perfectly diffuse)
"infinite" or that, what specular makes, is the ONLY perfect mirror. At least, in terms of blurryness.
However, 1 mil is QUITE perfect - you can't really see a differnce, then, anymore
