afecelis
by afecelis » Sat Nov 21, 2015 7:04 am
Hi guys,
I've set everything as usual in Blendigo's options to render and animation, however, when I click on the "animation" button only the first frame gets sent to Indigo and rendered, once it finishes the samples I set for it it doesn't pickup the next image
I looked in the forums but there's not much info on animation for Blender, can anyone give me a hand here?
regards,
Alvaro
indigoagogo
by indigoagogo » Tue May 25, 2021 4:46 am
2015!.....
Does Blendigo do any animations? I'm having the same issue. Looked at the manual and at this forum and experimented but it just renders one image over and over.
Is there a work around?
by Oscar J » Thu May 27, 2021 6:07 am
indigoagogo wrote: ↑Tue May 25, 2021 4:46 am
2015!.....
I've rendered plenty of animations using Blendigo. It's far from great but it can do the basic stuff. Can you describe your workflow more in detail?
indigoagogo
by indigoagogo » Fri May 28, 2021 5:10 am
Well I set up the scene and press render animation. Doesn't work.
Can I do a series of images and collate later?
by Oscar J » Fri May 28, 2021 5:38 am
It doesn't render it out as a movie, if that's what you mean. It saves images that you then have to put into a video software (or blender) to playback and edit.
indigoagogo
by indigoagogo » Sun May 30, 2021 9:22 pm
It only renders one image. It then constantly writes to that one image name till all frames are done... So in the end you only have one image.
burnin
by burnin » Tue Jun 01, 2021 6:16 am
Simple test animation shows fine here. Frame names saved by frame numbers located in "C:/tmp/[Scene-Name]"
Tested using: Blender 2.83.16 LTS w/ blendigo-4.3.0-3adc22b-master (exporter) & Indigo Renderer 4.4.16.
Edit:
Same test also working with Blender 2.92, Indigo Renderer 4.6.0 & integrated Blendigo exporter.
Zalevskiy
by Zalevskiy » Tue Jun 01, 2021 12:31 pm
del
Zalevskiy on Thu Aug 11, 2022 5:52 am, edited 1 time in total.
indigoagogo
by indigoagogo » Thu Jun 03, 2021 7:22 pm
Thanks for the replies. I had to use Cycles to bridge a gap but I will look at this again on my next work.
Users browsing this forum: Bing [Bot] and 31 guests
