The Beach House
for reinhard tone mapping -
I normally set the burn until the brightest area of the scene has detail or just slightly whited out. Then leave postS at 1 and use PreS as a exposure control.
Now with indoor scenes with some outdoor, you may find the burn number maxed all the way to 10, if that is the case then you will have to move the PostS below 1 as needed.
Anyway I think it is a given that with indoor scenes, just like in real life cameras if you have a bright outdoor light coming in and your focusing on it, the scene will ether be right inside, but over exposed outside or vice versa
in your case possibly the sky is too bright, maybe try lower sun angles and higher turbidity. Also add surrounding objects to block the light as it would in real life with other buildings and walls etc
hey guys
thanks alot coolcoj for that advice. ok i re rendered last night, same scene just using only emiiters, values set to 150 and 17.5, once again it took FOREVER to resolve but the end product is my best so far, all i need now is curtains on the windows
- 12 hour render still noisy
- im1186333965.png (591.89 KiB) Viewed 2896 times
- Kosmokrator
- deltaepsylon
