SolidWorks Exporter
not sure about the obj importer with the free version but i'll post.
please let me know.
remember you still need to export from an assembly. it dosn't matter where you put macro and you don't have to make a button to run it. it outputs the obj to the same folder your assembly is saved in.
with the obj importer i find the mesh import option works better, other than that i see no difference. once imported select the new group, go to soften edges and select soften coplanar.
please let me know.
- SW_Obj_Export.zip
- (156.89 KiB) Downloaded 559 times
- Sketchup_obj_import.zip
- (1.39 KiB) Downloaded 505 times
jeffr, i hope this is ok with you i guess i should've asked before posting parts of your code.
by the way have you considered the select by material macro for SW this would enable the easy selection of similiar material geometry so it could be saved as a seperate part, then these seperate parts could be re-assembled in a assembly and exported as obj. then it would be easy for re-texturing in a modeling app.
P.S i noticed the obj export doesn't export surfaces, any way to include these?
@xrok1
I tried the importer with free sketchup on various obj files from various sources and it works using the mesh option (although its definitely v. slow on large models) however for some meshes there are a number of holes in the result...in some cases a great number.
when I try to create a face it tells me they are not planar..I guess there is a difference in precision between applications.
the other import option seems to hang or perhaps it is just extraordinarily slow? so far using vrml and blender is getting better results for me.
see attach for a successful import of a rough laser scan of my phone I made using DAVID laserscanner. this took 5 mins to open and was 37,000 faces...
but some of my stuff like the motorbike has over 500,000 and one or two have been1.5 million so dunno...
the SW obj exporter would not work for me. I tried making a button for it as well but same..unless I am doing something completely wrong...
- chopper.jpg (109.16 KiB) Viewed 28028 times
- obj import.JPG (44.11 KiB) Viewed 28034 times
(SW)it is very quick it only takes a couple of seconds for me to export quite complex stuff.
make sure and check the folder where the assembly was saved?
note the exporter doesn't work with surfaces, and exports in inches.
thats about all i can think of to try.
(sketchup)this is an exerpt from the script:
# Adds sub-menu "Import OBJ" under the Plugins menu.
# ** THIS CAN TAKE A LONG TIME TO LOAD THE FILES **
# Note: Some .obj files have a very small scale and faces may not
# be created in such cases.
jeffr,
hey check this out! its a obj exporter with material support. i can't get it to work by i'm sure you can.
let me know.
http://swapi.wordpress.com/2007/03/25/objmtl-exporter/
let me know.
That's actually the script I used to learn how to export obj files in the first place
Not sure if having an obj materials file exported at the same time would make any difference.
I have got the script set up to use the SW settings to make a material (not uploaded yet). I haven't finished getting all the material settings in yet.
I also added a couple buttons. One to export just the igs scene file and another to export only the obj file. These are in addition to the button that exports everything and renders.
The problem I'm encountering at the moment is that Indigo 0.8 and 0.9 both choke on large files. I have an epson robot model that I try rendering and it just can't do it.
I've tested the obj in a different renderer (you know which one) and it takes it no problem so I know the files ok.
P.S. oh yeh. The original script wouldn't work for me either. It took some changes to get it functioning.
Users browsing this forum: No registered users and 131 guests
