bidir an strange colors
Macrob
Post by Macrob » Sun Jul 29, 2007 2:06 am
Hi! I play with a scene and sometimes I get "strange colors". When I change the distance to the object (water) it works. :shock:
only Metropolis, no bidir
bidir; Reinhard 2/3
bidir-picture "pimped" with Violet linear, full exposure, smallest contrast.
DaveC
Post by DaveC » Sun Jul 29, 2007 2:16 am
Is your water a specular object with transparency on, or is it glossy_transparent? I had similar problems with a specular material... i believe it is a bug the nick is currently working on
Macrob
Post by Macrob » Sun Jul 29, 2007 2:19 am
Specular, transparent, IOR 1.33.
OK, a bug :(
DaveC
Post by DaveC » Sun Jul 29, 2007 2:27 am
Try changing it to glossy_transparent.
tobak30
Post by tobak30 » Sun Jul 29, 2007 11:11 am
i too got some trouble with the material settings. i have made a simple wave wit a fluid material inside. and when i have applied the glass material in blendigo the material just turn out black. dont know what to do really. is that one part of the bug too? or is there any secret settings i have to do? I have set the material sto specular and hva had glossy transparent and just specular on it. with some different settings for the transparent thingy. like 1.33 and 3.00 and 1.55 etc. but it allways stays black.
Macrob
Post by Macrob » Sun Jul 29, 2007 8:59 pm
Hmm, check the normals, reduce gain, ... (?)
Post by OnoSendai » Sun Jul 29, 2007 9:27 pm
I think the error might be due to the glass intersecting the table.
Try moving it like 0.5mm off the table.
Macrob
Post by Macrob » Fri Aug 03, 2007 5:25 am
HI Ono! It does not work :(
I deleted the glassplate on the table and had the glass not intersecting the table. But the water intersects the glass.
Still funny black-green-yellow pictures after a short time of rendering.
Post by OnoSendai » Fri Aug 03, 2007 5:26 am
Can you upload the scene pls?
Macrob
Post by Macrob » Fri Aug 03, 2007 5:53 am
.igs or .blend?
Post by OnoSendai » Fri Aug 03, 2007 6:01 am
igs thx
Macrob
Post by Macrob » Fri Aug 03, 2007 6:15 am
I deleted some stuff (door, radiator, picture, ... ) because the igs is 25 MB.
It still renders ok(?).
Can I post the original filesize?
Post by OnoSendai » Fri Aug 03, 2007 6:34 am
25MB is a bit big...
Macrob
Post by Macrob » Fri Aug 03, 2007 6:40 am
The reduced scene still renders with no problems. ??
I try to get it smaller with funny colours.
Macrob
Post by Macrob » Fri Aug 03, 2007 7:10 am
Here we go
4.igs.zip
This works. I deleted some stuff
(1.71 MiB) Downloaded 201 times
3.igs.zip
zipped
(2.58 MiB) Downloaded 215 times
