CoolColJ's test pics thread
thanks
I am doing a render of that building again without the texture, and with that green glass staue in it plus some metal material on the railings
anyway - I just did a MLT only version for 10 hours, looked ok, and I am halfway through the Path tracing only version.
One thing I noticed that the MLT version became nice and smooth in the glass area very quickly. The Path tracing version still remains rather patchy in the glass area after 1000 samples, but the floor area below the railing cleared up much quicker. Also the Pathtraced version seems to be much more accurate in the statue,even after half the sample count I can see details and highlights I can't see in the MLT version!
Now technically hybrid would get the best of both worlds, but it is a lot slower and it won't since most of the pic is indirect lit...
Now I would like MLT to be as accurate as the PT version, since the smoothness of the glass area is much nicer, now is there a setting to get it as accurate as the PT version?
Maybe large Mutation probbality to 0.9 and max change to 0.1 or higher? MNCR to 1000, bounce depth to 10000
I was using LMP of 0.1 to 0.4 and max change at 0.3 before, MNCR 500 and depth of 1000
pic of both versions to come - and I am experimenting with the above new values...
MLT vs PT
here are the pics
top is MLT and bottom is Path tracing - both rendered to 2000+ samples around 10 hours on my P4 3.2ghz system
you can see the MLT is much smoother in the glass area, PT was very slow here and didn't start to smooth out until after 1500 samples, but is still grainy. But the PT rendering is much more accurate in the glass statue, you can see more highlights in the hands etc
I think if I push the large Mutation probbility to 0.9, and the max change to 0.01 maybe it will be as accurate?
- CCJ_BuildingStatue2000+samples_MLT_vs_PT.JPG (242.56 KiB) Viewed 8590 times
starting to get a good handle on Indigo's outdoor lighting and tonemapping settings
if you set Max mutation change to a very low figure like 0.005 to 0.002, you will find the caustics developing much faster and clumping together, very early within 150 samples as shown here
top pic is with a Max Mutation change for 0.9 and bottom pic with 0.0025 --> you can already see big chunky caustics after 150 samples
you can also see the normal smoothing issue I mentioned in the general section....
- CCJ_MaxMutChange_Comapro.JPG (63.91 KiB) Viewed 8572 times
after 6 hours of render time - 4400 samples.
plenty of caustics in the scene - on the mech itself, especially the top part, on floor, side and back walls. Caustics are still being added into the render right now, so maybe another 6hours and there will be more and smoother etc
yeah there are smoothing normal issues....
added some bloom
doing another render with the small Mutation Change value of 0.002 and see how it compares
added some bloom
- CCJ_BehemothMech_test.JPG (91.99 KiB) Viewed 8528 times
Well I tried the 0.002 setting, and while it looked smoother in caustics, it also had other problems like orange spots, whch I couldn't get rid of even resuming with other settings...
here is what it looks like after many hours and 15000 samples!
probbably over 24 hours now, but not much more
I used a ton of different settings on each render resume so not really a valid comaprison... anyway not a whole lot different looking, yeah caustics are more dense , smoother and more developed. Plus a little cleaner and more subtle shading in the darker areas, but not 10,000+ samples better
- im1185487612.JPG (89.29 KiB) Viewed 8426 times
A texture test that went wrong, looks kinda cool
man if I only could get my textures settings as I use in Cinema 4D the same way in Indigo...this texture works fine Cubic mapped in C4D.
Trying to UV map this would take way too long and more complicated than it needs to be
right now I'm getting frustrated as hell with using textures in Indigo. It keeps telling 3 component jpegs not supported?! Jpegs are jpegs right?
So I convert them png files, ok renders it fine, and then next render I try, it will tell me the files are no longer png files and gives me an error!!!
So I convert them to BMP files, works fine for diffuse textues, and then I try it on bump map and it says 8 bit files not supported!!!!
arghhhh
arghhhh
- im1185521689.JPG (96.75 KiB) Viewed 8366 times
thanks - another day and I feel better now
Did this yesterday, I love the quality of this render.
It's of a Russian IS-2 WW2 tank
One thing I like that it doesn't look like a "toy". You can sense the weight and size of the tank.
Usually in GI renderers it would look pretty toy like
I'd imagine, when full textured, bump and specular mapped it would look pretty photo realistic
But right now I am in no mood to export such a high poly model and test render when I have to sit through 10 mins worth of normal messages from Indigo with a Cindigo exported scene
Maybe I will try it in Sketchup if the exporter works with the free version, I can't get my head around blender right now...
top pic was rendered in Path Tracing, 2.5 hours, 1500 samples
bottom pic in MLT mode, just under 2 hours 1300 samples
- CCJ_IS2_test.JPG (101.81 KiB) Viewed 8296 times
You know, if you ever need help getting your head around blender, there are loads of people (myself included) willing to help you get started. And there's the brilliant video tutorials (I mean BRILLIANT) on http://www.blenderunderground.com . You should have a look.
If you just don't like blender, ignore this post
Cindigo just exports UV mapped Textures correctly (as told in the Cindigo development Thread!)CoolColJ wrote:A texture test that went wrong, looks kinda cool![]()
To convert your cubic mapped texture to UVM, do it by hand (lol) or simply check the attached picture
To get your jpgs textures working in Indigo sinply use jpg's and save them in basline mode,
otherwise Indigo wont be happy!
Indigo doesn't like 8bit textures to (greyscale bumps for example)... and if Indigo tells you, it doesn't like 8bit, don't be sad, but convert it to a standard 24bit pictureCoolColJ wrote:So I convert them to BMP files, works fine for diffuse textues, and then I try it on bump map and it says 8 bit files not supported!!!!
- uvm.png (18.75 KiB) Viewed 8224 times
- jpg.png (14.66 KiB) Viewed 8224 times
well I normally use ACDsee to do all my image conversion, so I don't have all those options, that's why I got frustrated
man why can't Blender be as easy to use as Google Sketchup? Look at the flash video - so easy, hell why can't any 3D program be that easy to use? Google will rule the earth!
http://www.sketchup.com/?section=product
Well, I don't know about that, but SketchUp is by far the fastest and easiest modelling program I have ever used (except for organic stuff...). You can pick it up in a few minutes and be creating awesome models in less than a day.CoolColJ wrote:Google will rule the earth!![]()
And...if you haven't figured it out yet, the exporter works with the free version of SketchUp.
thanks for the exporter! I love it, I can even go and edit the script to change some default settingsWhaat wrote:Well, I don't know about that, but Sketchup is by far the fastest and easiest modelling program I have ever used (except for organic stuff...). You can pick it up in a few minutes and be creating awesome models in less than a day.CoolColJ wrote:Google will rule the earth!![]()
And...if you haven't figured it out yet, the exporter works with the free version of Sketchup.. You can import 3DS and OBJ models with it so I assume you won't have any trouble getting your models in.
Sketchup is so easy to use, within minutes I got this scene up in Indigo 0.9 Test 3 - imported the Indigo test scene Cornell box, changed a few materials using the sketchup factory material/textures, fiddled with some exporter material settings, and wham bam thank you mam rendered a few images.
LOL you can even export out the default Sketchup figure
Good for scale purposes though
first one rendered for 1+ hour in MLT mode, 0.4 Mutation probability, 0.03 max change, 530+ samples.
2nd one in 1.5 hours, 700 samples
That box I used some metal textured material from Sketchup, and turned it into a phong material within the exporter with bump and specular mapping from the same texture. Although I should have used the aluminium NK data
I drew a square at the back and made it into a 100w light, a flat circle above as another 100w light and off course the cube acting as an 100w emitter.
I was able to workout most things. Except for some reason I could not get the material applied to the floor/cylinder to work
SO easy and fast - and if you have a quad core you could have 2 or more test renders going at once! I had 2 with my hyper threading single core P4
All this power and ease of use for free!!!!! I didn't even read the instructions
Man for quick visualisation of space and buildings/rooms you can't beat this. I can see why architects and such would love it
only problem is that is quite memory hungry, I couldn't import the tank into sketchup into it without killing all my memory at 40%, whereas Blender/C4D will have quite a bit of memory left. I have 1 gig. My new system will have 4 gigs though
Question Whatt how do I get the sky and sun up? I have it selected in the exporter, but I figure there must be something else I need to do?
now to work out how to save a camera position in Sketchup...
I finally have the setup I have longed for after mucking about in GI renderers all these years, gonna have some serious fun now
- CCJ_Sketchup_test.JPG (120.62 KiB) Viewed 8151 times
