kimal73
by kimal73 » Wed Jul 25, 2007 3:15 am
i have blender 2.44, indigo 09t3, and blendigo 09beta3. I have installed blendigo_v09t3s.exe on my pc and the files Indigowrapper.conf in .blender/scripts/bpydata is here with the exact path. i have copyed the previews folders of blendigo in Indigo folder, and i put blendigo in the blender scripts.
when i open blender rendering slot, the blendigo option don't appears between the others. Why?
SmartDen
by SmartDen » Wed Jul 25, 2007 3:30 am
Blendigo appears in Export Menu, not in Render
And BTW, if you intsall blendigo_v09t3.exe you dont need to copy any other files(e.g. Indigowrapper.conf) any more. It will be automatically done
kimal73
by kimal73 » Wed Jul 25, 2007 4:09 am
Oops! Tx
very well.
soon I will show you my before test with Blendigo. I have already used Maxigo. I would want to see progresses on the render time.
kimal73
by kimal73 » Wed Jul 25, 2007 4:23 am
Do you know if AO works correctly with blendigo? or is it to do in PS?
5OnIt
by 5OnIt » Wed Jul 25, 2007 4:29 am
kimal73 wrote:Do you know if AO works correctly with blendigo? or is it to do in PS?
I don't claim to be an expert, but since Indigo is an unbiased renderer, I don't think AO is even used. Any AO settings you have in Blender would be ignored.
kimal73
by kimal73 » Wed Jul 25, 2007 4:38 am
I suspected this. it does not import.
SmartDen
by SmartDen » Wed Jul 25, 2007 4:38 am
You can affect Ao by setting Supersamples parameter in Blendigo's Renderer section
kimal73
by kimal73 » Thu Jul 26, 2007 4:56 am
I set supersamples to 4. 4 it's the maximum value. only this is sufficient to create AO?
by OnoSendai » Thu Jul 26, 2007 4:58 am
erm... indigo doesn't use AO.
supersample_factor is completely different.
kimal73
by kimal73 » Thu Jul 26, 2007 5:22 am
ok. It's clear.
SmartDen
by SmartDen » Thu Jul 26, 2007 9:15 am
OnoSendai wrote:erm... indigo doesn't use AO.
Sure it don't! I confound it with AA. Sorry
by Zom-B » Thu Jul 26, 2007 11:11 am
if you want a AO enchanted Rendering, just do a Indigo Render, and a AO Pass from Blender.
Afterwards just blend them in your favorite Picture Editor
