Weird wavy lines and streaks
Tried another rendering, different model. Attached is a cropped portion of it-
notice there are "slices"? running through that are offset from the rest of the vertical lines/wall edges.
same problem maybe?
same problem maybe?
- little over an hour render time
rendered in hybrid mode - spa3_crop.jpg (44.34 KiB) Viewed 4171 times
mrCarnivore
- ThatDude33
It doesn't seem likely to be an exporter issue but it is weird that only crc and myself have noticed this issue (and both using SkIndigo).suvakas wrote:Can this be an exporter issue?
I am wondering if this problem could be related to camera aspect ratio or image dimensions. Or...maybe a bug in the supersampling code?
I just did a test with just one of the windows using the "Quick Export" option in Skindigo, still the same problem. I can post the log or send it to you, the .igs is still pretty big, but can email if you like.OnoSendai wrote:This is just bizarre;
crc: if this bug is really slowing you down, can you make me a nice simple test scene, and send me the .igs?
Also can you paste the log file somewhere or send it to me?
Than, I saved the window component out and opened, and it rendered fine.
Whaat--
I ran some tests changing the camera and aspect ratio, and didn't seem to make a difference, but I haven't been able to replicate the problem in a "control" environment. Also thought it was maybe an exr issue, but same thing happened with just "background" on.
