soxofaan:
Yep, blender also crashed there. Maybe python related, because did not happen with older blender versions.
DEV-thread - Blendigo v0.8 - material-editor-exporter
- joegiampaoli
I've not seen this mentioned elsewhere but blendigo seems to ignore blender's setting for whether or not to attach the material data block to the mesh or the object. If I have it set to object with the mesh empty it will just display the blank grey default for the faces concerned. It seems odd that blendigo wouldn't check for such a thing.
Great work zeugs, just caught mysef going in a dumb circle - loaded a scene tried to run blendigo 0.8 - error, checked for all the usual dumb errors, different blendigo versions, different file versions and then finally found it - with no object selected when you first run the script blendigo errors out with a 'NameError: global name 'activeObjectMat0' is not defined'. Hadn't crossed it any time before because I've usually tweaked something or checked a setting before going to blendigo, this time I just went straight to the script.
So only a minor one but might be worth a script tweak at some point in the future so that the script initialises ok?
